Forum rules
USAisDOA
by USAisDOA on Wed Jun 15, 2022 3:56 pm
shimmeD wrote: ↑Wed Jun 15, 2022 4:14 am
So what happened to the English chap with the bike shop? He used to respond almost to everything. He never read what he typed hence so typo's. Good dude... I forgot his handle. I used to really enjoy reading some of his exasperated responses to some of my off the wall post ideas, most of which worked for me. Einstein of all people stated that you never learned a damn thing if you don't make some mistakes.
So if you're out there Englishmen.. I built a gravel bike aluminum frame last fall mostly to play with discs. And I built triplet on both ends 16 8 front and back. Radial rear left----eight "stoppers", works just fine
enjoy this one englishman.
That was bm0p700f who hangs out at thecycleclinic.uk I think he got sick of coming here, shame that since I enjoy(ed) his posts.
to Malcolm.
And yes you're right Malcolm doesn't like weird wheel builds like yours!
Yes I remembered his name later.. Malcolm.
Per quote "weird builds" Mr UK built a get this, 12 hole rear wheel. I remember him whining about it was not a stand-up writer, and broken spokes made its use basically decoration on the wall. I think he weighed about same as me at that time 190 lb.
ChitMANO did allow radio lacing on the front on the right side disc. And if you know anything about a triplet, you might research that a little bit.. the smokes are counterposed on the front wheel left in the case of this front wheel build so everything is working when you apply the brakes.
Same for a radio lacing with lasers on the back left, everything is taking a load when you apply the brakes. And that tension is moved up to the center 1.5 taper. Works just fine.
Am I recommending this lacing pattern? Well.. this is quote wait weenies unquote... So with a little generic petroleum jelly it fits here.
I believe almost nothing I read and 'hear'
I believe roughly half of what I see with my own eyes.. in person.
I do not
carbon.. anything
shimmeD
by shimmeD on Wed Jun 15, 2022 8:44 pm
I miss Malcolm too. He did say once that he's affected by dyslexia hence the typos, that imo added charm to his posts of exasperation.
I'm using a rim-brake 16/8 rear with a 25mm tubular Farsport rim on a 'regular' but 16/8 drilled BHS hub. I like it and it performs fine, cavaet being that I'm of slight build not generating huge power by any stretch of imgination.
Less is more.
ultimobici
- in the industry
by ultimobici on Thu Jun 16, 2022 6:46 am
shimmeD wrote:I miss Malcolm too. He did say once that he's affected by dyslexia hence the typos, that imo added charm to his posts of exasperation.
Pretty sure posts like the one above yours are the reason many interesting & informative posters no longer frequent WW.
Sad loss.
ultimobici
- in the industry
by ultimobici on Thu Jun 16, 2022 6:56 am
USAisDOA wrote:Yes I remembered his name later.. Malcolm.
There’s an old saying that applies here.
Just because you can doesn’t mean you should.
As far as I can see, Shimano still prohibit radial lacing on all their hubs except for Dura Ace. They must know something you don’t……
ooo
by ooo on Sat Jun 18, 2022 6:23 pm
Shimano also offer radial/non-radial 8/16 lacing on 2021 Ultegra WH-R8170 rear wheels and 2017 oem WH-RS770-C30-TL-R12 rear wheels
viewtopic.php?t=167622 - j-bend/straight-pull centerlock hubs/wheels list with 8:16/16:8 and 7:14/14:7 lacing
alanyu
by alanyu on Thu Jun 23, 2022 8:49 am
berest wrote: ↑Wed Nov 24, 2021 2:06 am
Hi there,
Can anybody tell me please, what length should i go for the front wheel, if DT, actually, doesn't produce an Aero Comp spokes in 257mm length?
With rear wheel, everything seems to be more understandable - 260mm and 264mm, am i right? However, wouldn't it be better to go with 266 instead of 264 for the rear, left side, since the Accurate is 265.5 - which is way closer to 266, than 264. Or is it fine cuz i'm using 14mm nipples all around, which is longer option than regular 12mm nipples?
Thank you
Better go down. Spoke will be elongated around 1-1.5 mm under 100 kgf, which DT calculator has considered IIRC. However, spoke will also creep under tension with the time going. You won't like no thread left when you need to retension it 1-2 years later.
woodzyz
by woodzyz on Sat Jun 25, 2022 3:18 am
alanyu wrote: ↑Thu Jun 23, 2022 8:49 am
Hi there,
Thank you
Yes better to go down,if you aren't sure about the actual accurate length,go down and use 14mm brass nipple,problem solve
Aesch
by Aesch on Tue Jul 05, 2022 7:04 pm
I've recently built a set of gravel wheels with Farsports 32wide/36high asymmetric rims, 28H front and rear pillar 1420 spokes/12mm brass nipples on a set of Erase Hubs.(1410grams)
Since this set has impressed me a lot i'm looking to build another pair, to be used as a wider set for my road bike. I'm wondering however if I shouldn't build a set with slightly beefier spokes for the gravelbike and move this set over to the roadbike. any suggestions on where to look/what to look for?
Should i go for Pillar Wing spokes maybe? then the 20 or 21? or CX-Sprint? or it this all too much and should I just get another set of pillar 1420 spokes?
Any ideas and suggestions are welcome!
iamraymond
by iamraymond on Tue Jul 12, 2022 9:21 am
I'm searching for a lightweight alloy wheelset for an upcoming rim brake build. I'm 63-65kg and most of my rides include around 1000m of elevation. I'm not a strong rider (FTP = 225w) and love climbing hence the priority on weight. I don't rail down descents and usually take it very conservatively going down hill. I also never sprint. Some of the climbs are quite steep (10% or more) so I'm looking for a good alloy clincher wheelset. I plan to run 28mm GP5000 clinchers with latex tubes so I'd like a rim with a 18mm internal width
Here's what I'm thinking for a build
DT Swiss RR411 rims 20/24
DT Swiss Squorx nipples
Bitex RAF10-RAR9 hubs
Sapim CX Ray spokes
For a build of sub-1400g.
I've been reading previous posts in this thread about the DT Swiss RR411 rim, but they are for heavier riders who need a more robust wheel set. My priority is to build a light and comfortable wheelset.
What are your thoughts about this build?
bobones
by bobones on Wed Jul 13, 2022 2:31 pm
iamraymond wrote: ↑Tue Jul 12, 2022 9:21 am
Sapim CX Ray spokes
I would be concerned about this combo being a bit too flexy under load. You will notice a lack of stiffness more than a 100 g extra on the weight of the set, so perhaps consider a deeper, heavier rim or 28H on the back. I have used those hubs on a light build (Mavic Open Pro UST 24F/28R with brass nipples that came in at 1380g) and they're pretty decent apart from the tiny 688 bearings in the RAF10 which may require more frequent changing. CX-Rays are great spokes but they're very expensive compared to Lasers, D-Lights and Race, so maybe you don't need them for a shallow wheelset. It's tempting to build the lightest you possibly can, but stiffness should be a consideration; however, you'll never know if they're stiff enough unless you build them!
shimmeD
by shimmeD on Wed Jul 13, 2022 9:10 pm
I'm 10kg lighter and own Bitex/Pacenti V2/CX-Ray which is only used for (short) commutes nowadays. Since you can't get Pacenti rims anymore, substitute with Hed the best alloy rims. Kinlin is popular but I've heard that the alloy may be softer. Boyd is another option. Check with November Bicycles who build a fair few alloy wheels.
Less is more.
NickJHP
by NickJHP on Thu Jul 14, 2022 8:57 am
Not so. I have wheels I built 20 years ago, and when I put my tensiometer on them, the spoke tension hasn't changed from the values I recorded when I finished building and stress relieving the wheel. Absent the rim cracking around the spoke holes, the spokes in a correctly built wheel shouldn't lose tension with use. The yield strength of the stainless steel wire used for spokes is several times the tension that the spokes see in a wheel.
alanyu
by alanyu on Thu Jul 14, 2022 9:53 am
NickJHP wrote: ↑Thu Jul 14, 2022 8:57 am
Creep is not a thing related to yield strength. Solid can creep under the stress within its yield strength with time going. It becomes an issue when people build wheels with skinny butted/aero spokes and less counts (20/21/24), while on a traditional 28-round 2.0 spoke wheel, creep is negligible for years.
