i'm pretty good a sewing and did that before on my veloflex sprinter so might be worth a try.. just not sure if the patch from inside + neoprene contact cement outside woudl be enough.
Tubular Repair
Forum rules
Ok repair failed. Tried to patch the inner tube up using Park tire patch, but the tufo extreme will leak out once it’s pumped making the patch no longer sticky.
Any other ways to patch the inner tube?
The outside using neoprene contact cement worked!
I hope it wasn't Park Tool self adhesive patch? On the subject, they are garbage and if enyone is thinking of patching the tube properly should stay away from them.
I use Rema cement with latex patches cut from old Vredestein tube. The only thing I do before applying glue is to clean repaired tube section and the patch itself with some alcohol based cosmetic stuff.
Rema cement
Rema cement
Hi,
Bigger bottles of this sealants do not exist because the sealant tends to harden inside the container once it has been opened up.
IOW, oxygen tends to solidify the sealant.
Cheers,
Cheers,
Interesting.. perhaps that only applies to Tufo sealant? Orange seal and Stans all come in big bottles.fdegrove wrote:Hi,
Cheers,
Hi all,
I installed these new pair of Conti Sprinter (butyl tube) and rode 20km before getting a flat. upon inspection, air leaks from the base of the valve. Should I try add some sealant to see if I could salvage it? Bought it as spares a year+ ago, so not possible to ask the reseller for help..
I had a similar issue with a vittoria tubular and was not able to salvage it with sealant. ymmvnutty wrote: ↑Tue Aug 06, 2019 4:25 am
Hi all,
That's the weak spot for tubulars. IMO many ways to cause leaks there. And usually nothing to do but bin the tub :
1) Installing the tubular poorly, with lateral pressure on the valve, and eventually create a hole.
2) Forcing, twisting the valve sideways when inflating...
3) HItting a pothole, or big crack with the valve facing down.
Louis
Louis
- WinterRider
I've salvaged a few inner tubes using Super Glue products. See no reason wouldn't work for tub valves... 2nd application for strength helps. Degrease well before applying.... acetone.LouisN wrote: ↑Wed Aug 07, 2019 12:16 amThat's the weak spot for tubulars. IMO many ways to cause leaks there. And usually nothing to do but bin the tub :
Louis
Litespeed 2000 Appalachian 61 cm
Litespeed 1998 Blue Ridge 61cm
Fitness rider.. 1 yr from seven decades age.
That is my story and I'm stick'n to it.
Seem that my turn to post in this topic... Today had a sice cut puncture on almost new Continental Competition (only 200 km rode on this tire , and i have never ever own a tire that lasted this little km's, but i guess bad luck (or very gentle sidewalls) )
Seem that Continental's have very vulnerable sidewalls..
Last week had sidecut on Continental 4000 SII (it was not still punctured and fix the hole with superglue..But considering unsafe i replaced), but this was on 5000 km, so ok..
But Competiton just 200 km (at least i really liked this tire in that 200 km's ).. .And very strange how this puncture happened.. Fast ride today, i stopped to tap watter and when i start braking hisssssssss.. I thought first that is the rear one (Continental Sprinter more then 2000 km on which i had puncture two months ago, and put it Tufo Extreme Sealant), but bad luck..It was not rear Sprinter, but Competition.. Tried to fix with Tufo Sealant but failed (maybe i made mistake that i did not get with me brand new bottle, but one that i used two months ago, but shaked very well)...
So lucky that i had my spare Tufo tub which bring me home (25-30 km's from home)
So what are my option considering Competition are almost new?
1. Should i try brand new Tufo Extreme Sealant (now when i pump some higher pressure, let's say more then 4 bar, Tufo dont hold pressure anymore)
In meanwhile i put some pressure, put the tire with hole beeing down so will try again tommorow
2. Should i send for repair or try to reapair my self with unstiching base tape, then i unstiching tire and to try to replace iner tube and to put inside patch of the sidewall?
3. Just bin it?
This is how puncture look like:
3. Just bin it?
- Moderator
Thats a write off...
Sent from my SM-G977B using Tapatalk
Using Tapatalk
- wheelsONfire
I managed to damage a Conti Comp on the first ride. Used sealant and Co2, weirdest thing, the sealant started to bubble almost 360 degree.3Pio wrote: ↑Sun Sep 08, 2019 9:31 pmSeem that my turn to post in this topic... Today had a sice cut puncture on almost new Continental Competition (only 200 km rode on this tire , and i have never ever own a tire that lasted this little km's, but i guess bad luck (or very gentle sidewalls) )
3. Just bin it?
A buddy picked me up in his car, bringing a compressor. It didn't work at all. Went home to his house using a large compressor.
It just bubbled and bubbled all around the tire (360 degree).
I don't know why this happened. Now i realize, riding tubulars means bringing a spare tire and a Co2 cartridge.
It's not funny being stranded far from home along the rode. A taxi ride would cost alot!!!
Bikes:
Open *UP* (2016.04.14)
