New Nextie Rim Brake Rims
Forum rules
matty
by matty
Looking at building carbon rim brake wheels and these new Nextie RX rims look interesting as have not come across many that compare for weight
https://www.nextie.com/road-RX-series
Also thinking of h-works for the hubs which I only came across today
https://www.h-works.cn/collections/hubs ... %7EV-Brake
Anyone have any experience with either?
wheelbuilder
by wheelbuilder
What are you building them for? Those weights are good but they are very narrow.
bobones
by bobones
They're standard width for rim brake rims and perfect for 25mm tyres. If you''re building light wheels with light rims, why put on heavier tyres than you need?
wheelbuilder
by wheelbuilder
bobones wrote:They're standard width for rim brake rims and perfect for 25mm tyres. If you''re building light wheels with light rims, why put on heavier tyres than you need?
Which is why I asked what they are being built for.
OtterSpace
by OtterSpace
yeah.
What bike are you using them on, what size tires do you want to run, what is approximate rider weight range, and what are you trying to optimize for aero, crr, comfort, crosswind stability?
From that info determine a rim depth, inner & out width, and only then start optimizing for weight spoke type hubs etc.
toxin
by toxin
Rim profiles are awful, if that's something you care about
bobones
by bobones
toxin wrote:
Wed Nov 20, 2024 11:59 pm
They're for rim brakes. With 25 mm tyres on them, they'll have an elliptical profile. What's so bad about that?
bobones
by bobones
wheelbuilder wrote:
Wed Nov 20, 2024 11:39 pm
Yeah, but for rim brakes they're far from "very narrow".
Mr.Gib
by Mr.Gib
What seems to be missing is the info about the width of the rim at the widest point. They appear to be fatter in the middle in displayed profiles. Maybe they bulge out to 28mm+?
Curious - what don't you like about them?
toxin
by toxin
The widest point would be better being a little closer to the tyre. The "bottom/trailing edge" would be better a little sharper. The bulge is basically useless on the smallest sizes.
They could be pretty good for crosswinds tho
matty
by matty
Didn't expect so many replies. Bike is a 2002 Lemond Tete de Course running 10 speed Campagnolo Record and skeleton brakes. So restricted by what I can fit and looking for something with grooved brake track and lighter weight than my current shamal ultra.
I love this bike and would struggle to get something more modern to replace it hence keeping it going for as long as I can with wheels being the only further area to upgrade without replacing groupset to gain some extra gears.
matty
by matty
I still have yellow veloflex black tyres max width 25mm and some old corsa cx with yellow stripe in 23mm. Probably would also try Pirelli P Zero Race in either 26mm or 28mm clearance allowing. Bike has yellow accent theme from the original decals and bar tape, saddle, lever hoods.
wheelbuilder
by wheelbuilder
From your additional info those Nexties will be good.
alanyu
by alanyu
This shape, IME, is much less stable than curved-V (bontra XXX, LB AR) in similar width (widest point around 28)
