Search, reliable carbon rim, >30mm internal
Forum rules
bedampft
by bedampft
I need some rims for a new Gravel (long distance) wheelset.
Internal width should be at least 30mm, rim hight 45 -55mm.
Has anyone a reliable source?
I found this, but have no idea about Company itself
https://carbonal.net/en-de/collections/ ... arbon-rims
OtterSpace
by OtterSpace
light bicycle wg44
Reputable vendor 30 inner hooked 44 deep 40 external. Runs 42 WAM with 38 marked slick tires. With wide tires the effective depth is quite deep. The wide outer helps for aero transition to wider tires
I have a writeup on my build with them here: viewtopic.php?f=10&t=173076&start=15#p1835223
There is also a zipp xplr 32mm inner hookless but I'd go with the wg44 over it if I had to buy again.
satanas
by satanas
FWIW, BTLOS have recently come out with similar rims to the LB WG44 & Nextie AGX i30 x 36 or 45mm rims, in i29/e36 - MC35, MC40, MC45 & MC5, where the number is the depth in mm. I know nothing about these but some people here seem to think the company is okay.
https://btlos.com/all-road/ar-clincher- ... lter=48,16
AFAIK the new Zipps are the only non-MTB rims wider than i30.
