Analysis paralysis - wheels - weight or aero?
Forum rules
mk92
by mk92
Hi everyone,
I’m currently building an Aethos and I'm stuck deciding on the wheels. The options are between the Lightbicycle AR25 (990g, 25mm) and the Wheelsfar Hyper (1190g, 50mm). The change would bring the projected weight from 5.6kg to around 5.4kg.
The Aethos will be my second bike, with my primary bike being a Dogma with ENVE 4.5 wheels, weighing a total of 7.4kg. Given this, would it make sense to go for the lightest possible wheels to create a noticeable difference between the two bikes? On the other hand, since I live in Sydney, Australia, where the terrain is more mixed than purely climbing-focused, maybe the 200g penalty for the deeper rims is worth it for the added aerodynamics.
Thanks in advance!!
TobinHatesYou
by TobinHatesYou
Get the AR25s, though keep in mind their “hybrid hooks” may as well be hookless. Don’t use narrower tires than 28s, and note the max pressure rating for the rim is 70psi, not even 72.5psi.
cheapvega
by cheapvega
Going fast and holding speed is fun. I would go with the 50mms.
HannibalLecter
by HannibalLecter
Both.
Id buy the new turbo wheels, 50mm depth, the quality is exeptional. When laced with carbon spokes they are probably below 1300g.
My ideal build would be these rims, nonplus hubs, titanium spokes. 1200g, reliable metal spokes, nothing too proprietary. And although not by any means cheap, still below 2000.
I have the ar465 rims and I can attest to the quality.
Requiem84
by Requiem84
mk92 wrote:
Tue Nov 12, 2024 12:08 pm
Hi everyone,
Thanks in advance!!
The more logical choice will be the 50mm's.
200grams won't give a meaningfull difference during the climbs in speed. It will FEEL faster when you stand up or accelerate. But when you'd do a timing of your loop you won't see much difference. The 50mm's will be a bit faster (especially if there is some yaw). And it looks MUCH better (imo).
In the end also the 50mm's will not be MUCH faster, so the best answer probably is 'buy what you like the most'.
TobinHatesYou
by TobinHatesYou
He already has a semi-aero bike with ~50mm deep wheels. The logical choice is to avoid redundancy.
Requiem84
by Requiem84
TobinHatesYou wrote:
Tue Nov 12, 2024 1:07 pm
Adding 200grams to his 5.4kg bike won't make it the same as his 7.4kg aero bike.
MagicShite
by MagicShite
I actually agree with THY, just get the lightest low profile you can get. It's an aethos, why bother with aero?
I wouldn't want to use tubeless tho, much prefer running TPUs with clinchers.
OtterSpace
by OtterSpace
Yup, pretty obvious choice if you already have another faster bike. Optimize each for what they are good at.
If you only had the aethos something around 40mm would be a good bet but you already have an on meta bike. Build this one up light towards the advantage of the aethos platform. Id avoid tubulars and anything super exotic as I think those match better with rim builds.
gurk700
by gurk700
Doesn't matter. Shallower profiles look better on Aethos.
Current bikes: '24 S-Works Tarmac SL8, '24 Specialized Allez Sprint
Disgusting list of bikes owned
Yoln
by Yoln
I'm in the wheelsfar train, mostly because the LR25 with CX-ray are going to be noodly. but 50mm is a bit much IMO to climb, just don't like the feeling of it.
Carbon spokes, 35/45mm deep, hooked rims, is the sweet spot for me.
If your user case is to keep some versatility for your bike that would be my choice. If your goal is to make a HC wheelset that you use only for KOM chasing and HC racing once in a while, I would go with the 25mm.
cheapvega
by cheapvega
MagicShite wrote:
Tue Nov 12, 2024 2:23 pm
Because speed is fun. I run 60mm wheels on my external cable bike. It's a little less snappy up climbs but I get way more back elsewhere. 40-50mm is good and 25mm is to far IMO.
spdntrxi
by spdntrxi
since Enve 4.5 are already owned... shallow wheel makes sense.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault x2 drop and flat bar
Tpduke112
by Tpduke112
Buy the shallow wheels and put the Enves on if you want aero.
‘22 Bianchi Oltre XR4 Disc - Fast Race
‘25 SWorks SL8 RTP - Climby Race
‘24 Specialized Crux Pro - Dirty Race
‘22 Bianchi Sprint - Practice Race
‘17 Bianchi Pista Sei Giorni - Dont Race
wltz
by wltz
I'd probably go with Farsports Hypers, but in 35mm. Shallower wheels will match the Aethos lines better, however LB's AR25 aren't even marketed as a road wheelset, and I agree their spec suggests they will be noodly.
