^ My guess is people who go touring; some tyres aimed at tourists are slow AF so it's a legitimate concern, and time and effort wasted all adds up.
Hidden gems - fast tires
Forum rules
![](https://weightweenies.starbike.com/starbike-bike-shop.gif)
the new maxxis high road sl scored high in the latest Tour Mag. they claim almost as fast as GP5k str
Current Rides:
2025 Giant Propel Advanced SL 9270
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
ex 2019 S-works SL6
We've now done the test on the Bontrager RSL in size 26mm, looks like it'll be just behind the Conti 111 in terms of Crr but full data out on Wed/Thu I think!xav wrote: ↑Fri Sep 27, 2024 9:43 pmI reckon we could do the RSL soon-ish, will definitely add it to the listBigBoyND wrote: ↑Sat Sep 14, 2024 9:42 pmThe BRR voting pattern for road tires makes me think people prefer to see common tires tested 10 times in different sizes than to find hidden gems. The Bonti RSL might fall off this month for a 26mm Aero 111 which is sized like a 24mm tire. Something I didnt think anyone would choose in 2024.probably in 26 & 28 before anything else
AeroCoach UK
www.aero-coach.co.uk
TobinHatesYou wrote: ↑Mon Sep 23, 2024 11:44 pm
Just got back from the shop and got a chance to compare a 28mm Corsa Pro and Aeolus RSL side-by-side.
- Casing width is identical
- The Aeolus RSL tread cap is 7-8mm wider, it looks like it has at least 52% tread coverage, which would be greater than any other tire in this class.
- The Aeolus rubber felt grippier when I ran my finger across it, but that could be down to the tread pattern.
Called it!
While the tread compound seems to be the same, there's basically no reason to buy an actual Corsa Pro or Corsa Pro Control over the Aeolus RSL. Wild.
Agreed the RSL is better in every way plus where I am they are 25-30% less expensive than Vitoria branded ones.TobinHatesYou wrote: ↑Tue Nov 26, 2024 8:54 pmTobinHatesYou wrote: ↑Mon Sep 23, 2024 11:44 pm
Called it!
Just bought two RSL's on sale under 100€ so couldn't resist such a good offer.
Scott addict rc - DuraAce 6.9kg
Sp cycle G056 gravel - Sram mullet AXS 8.4kg
We had it as a bit worse than the Corsa Pro actually, data here: https://www.aero-coach.co.uk/time-trial ... tance-data
AeroCoach UK
They're 90 euros each in the NL...Kubackjeee wrote: ↑Wed Nov 27, 2024 1:29 amJust bought two RSL's on sale under 100€ so couldn't resist such a good offer.
Not sure why anyone would spend over $60 for a tire, not alone over $100 if you're not racing, for a tire that will only last 2,000 miles and some only last 1,000 miles...but I'm a tightwad, owning businesses does that to a person.
I always look for closeout deals on tires, I have a pair of Specialized S-Works Turbo Road Tire 2-Pack, 700x24mm coming around the 7th I got from Excel Sports for $45 including taxes and shipping. While those tires are not the fastest tires on the block, I'm not freaking racing, so for me to ride 40 miles and return home 15 to 30 seconds later isn't going to bother me.
Yeah, hard to justify extra 30€ per tire when corsa pro can be bought in EU for 60€.Aesch wrote: ↑Sun Dec 01, 2024 6:17 pmThey're 90 euros each in the NL...Kubackjeee wrote: ↑Wed Nov 27, 2024 1:29 amJust bought two RSL's on sale under 100€ so couldn't resist such a good offer.
