Continental Aero 111
Forum rules
TobinHatesYou
by TobinHatesYou
cyclespeed wrote:
Thu Nov 28, 2024 11:01 am
The 111 in 26 might be a good front choice, but the price pushes credibility for me.......
26mm Aero 111 were immediately 26.1mm at 100psi on 22.4mm internal rims.
25mm GP5K TT TR were immediately 27.5mm with the same settings.
Both tires stretched ~0.4mm overnight.
According to the ETRTO 25-28mm tires are to be sized against 19mm rims, 29-34mm against 21mm and 35-46mm against 23mm. It would be ugly from a marketing standpoint, but it would make sense to offer a size range of 25-27-31-34-40mm for reasonably spaced real size development on 19-21-23mm rims.
maxim809
Administrator
by maxim809
Thanks a bunch xav. Really helpful.
I feel the Aero 111 is both an inflection point on Cartesian-Coordinates, and the completion of a full cycle on Polar-Coordinates.
Put less cryptically, history may finally repeat itself but this time in the right way. JPB@SwissSide has been advocating for years to consider going narrow on front for aerodynamics, wide on rear for rolling resistance. Like most things in Road culture, adoption has been slow but steady.
It has been 17 years since Continental announced the Attack/Force tire set in the Fall of 2007. This combo came with two tires: the Front Attack at 22mm and Rear Force at 24mm. The front was optimized for aerodynamics. The rear was balanced for the Trifecta of puncture resistance, rolling resistance, and comfort.
It didn't exactly catch on. People just bought matching GP4000's and called it a day. Conti was too ahead of its time.
Finally, in the Fall of 2024, SwissSide busts open the doors with a Front optimized tire in a collaboration with Conti. A lot of people in my area have already picked them up and putting miles on them. And this is literally only the beginning (again). So I really hope this inflection point continues to project upwards, and new challengers with different mix-and-match philosophies emerge to provide even more varieties of optimization.
I think a sign of mass adoption will be when matching tires looks old fashion to even the Average Joe and Jane. Not sure if we'll ever get there. But for today, here we all are.
I'll put this 5 year old vid here. JPB is obviously talking 23mm tires in the context of a TT bike's front tire choice. I don't want to assume, but I'm sure he would recommend 26mm or 29mm for a Road bike, and achieving whatever the Trifecta means to you in the back.
https://www.youtube.com/watch?v=ahcszyobF4U
TobinHatesYou
by TobinHatesYou
TobinHatesYou wrote:
Thu Nov 28, 2024 3:47 pm
They've stretched again after a ride. They are now 26.5mm and 27.9mm at 75psi, 27mm and 28.4mm at 100psi
justinfoxphotos
by justinfoxphotos
maxim809 wrote:
Fri Nov 29, 2024 7:08 am
Dat mic drop tho! :beerchug:
TobinHatesYou
by TobinHatesYou
After a couple rides on the Aero 111s I'm leaning toward using them most days. Wind tunnel testing doesn't account for instability / control issues from occasional wind gusts leading to easing off the power, psychosomatic increases in HR and what not. Ideally I would use the GP5K TTs on the truly windless days with a 100mm deep front wheel, with the Aero 111s on my HED V84s on days with some wind.
Having a very stable setup is crucial for me because my armpads are as close together as possible. I'd been considering spreading the pads apart by ~4cm in order to gain back some stability, but with the Aero 111s, I'll probably keep the narrow pad stance.
NordicSal
by NordicSal
So for this winter - do I pair it with a 28c GP5k AS or a 32c? For the summer I'll pair it with a 28c or a 30c GP5k.
FuCH
by FuCH
After the first ride the installed tires on DTSwiss Arc 1100 with 20mm internal the 29 Aero are measured 28.1mm, 32mm P-Zero TLR RS - 32.9mm.
P.S. Intallation of these 111 Aero was not as hard as expected using a proper tool, the P-Zero tire was harder to install.
Kevin7767
by Kevin7767
NordicSal wrote:
Fri Nov 29, 2024 10:52 pm
I went with a 32 in back and it is amazing. I didn't notice any difference in weight and it feels great. I'm setting PRs everywhere and never going back.
BigBoyND
by BigBoyND
FuCH wrote:
Mon Dec 02, 2024 10:28 pm
I can't remember the last time I needed a tool to install a tire. Must've been years ago. If any tool is needed, then the tire is too tight.
TobinHatesYou
by TobinHatesYou
BigBoyND wrote:
Tue Dec 03, 2024 6:40 am
Alex Honnold might be able to get P Zero Race TLR RS tires on by hand, but most of us are better off just using a tire lever. Inserts also make things more interesting.
Aeo
by Aeo
Any reports about ride quality? I assume it still has the Continental garden hose DNA and doesn't come close to cotton based tyres by Vittoria or Veloflex nor whatever Michelin or Tufo are doing
Giant TCR Adv SL '23 (6.1) · BH Lynx Race Evo '19 · Seraph GR029 '21 (7.7) · Canyon Inflite AL '14
JWTS
by JWTS
Tue Dec 03, 2024 6:48 am
It's really strange, because I just installed a set of 30mm RS's on Reserve 42/49's. Literally the first time I've installed a tubeless tire without a lever (normally don't even try due to my arthritic hands...). Hands down the easiest tubeless tire I've ever installed. Not sure how much the rim contributed to this, but a 28TT was still tighter on these.
Aesch
by Aesch
Interesting, I'm looking at a combination of 111 front in 26mm and the P-Zero TLR RS in the back in a 28mm for my rim brake madone. I hope they'll eventually end up at ~27mm WAM front and ~29mm WAM at the back on 21mm internal rims.
JWTS
by JWTS
Thu Nov 28, 2024 12:35 am
World Tour teams are sponsored, and the GP5K TT is a great tire so I would happily be sponsored by Continental. Ineos famously didn't have a single flat in the TdF while running the GP5K TT almost exclusively.
Since we're not sponsored, we can mix-n-match whatever tires we want without breaking out the black marker pen. The P Zero Race TLR RS is close enough in Crr, has noticeably more grip even in dry conditions, and it's a more robust tire. The only thing is the tread compound isn't as hard wearing, but that's not something I care deeply about.
For windy road races, Aero 111 + GP5K TT TR
For technical crits, Aero 111 + P Zero Race TLR RS
For rainy days, Aero 111 + P Zero Race TLR RS
For 10mi TTs, GP5K TT TR x2
For long TTs + strong winds, Aero 111 + GP5K TT TR
Sure, world tour teams are sponsors--and I, thankfully, am not longer bound to ride Schwalbe Pro 1's in the PNW (black marker is real!); but those teams can opt for the TT and currently they all have access to the 111. Many still opt to ride the 5000S, including in the 28 (so it's not an ETRRO thing). And funny enough, the year after Ineos (no flat year), the following year some riders opted for the S of the TT.
Personally, I'm on board with the TT, but the fact is that the S is certainly still more than relevant. It consistently tests (slightly) faster than the RS, it's known to have good aerodyanamics (the eyeball windtunnel suggests the Pirille will do well there as well), and the handling is a known quantitity.
As far as the RS compares to the S, "more robust" is questionable, at least in the 30mm size. There's significantly less tread coverage on the RS vs. the 5000S, and ultimately I think that may count for more? I mean, I'd trust either tire, but it's not so clear cut that the RS is a more robust tire in that size. In a 28, sure.
Regarding where the Aero 111 fits into the discussion, I found it pretty interesting that in Aerocoach's testing on a deep wheel, the 5000TT and Aero 111 were a wash out to 15 degrees, so clearly it's wheel-dependent. I also wonder about the aerodynamics on a wide wheel? Clearly it offers a signficant improvement on some wheels in terms of aero, particularly more shallow/narrow wheels, and it seems to offer a handling advantage according to some (not all) reports. I do wonder what happens is super-windy conditions when you get past the stall angle as far as handling is concerned? I could see the tire handling really well, until it doesn't...
For me, I'm gonna roll the 5000S TT's next year on the road. I've found that in wet conditions, lower pressure makes the wet grip acceptable, and for me, I'm just used to how the tire handles. I'm using the RS's right now as a winter tire to try it out. I like it just fine, but at least in the 30 it has some odd handling characterists to me pushing it on a fast descent. It seems to grip well and then get a bit dicey when really leaned over. I had some rear slippy and front wheel chatter that I didn't love. And ultimately, for me, familiarity with a tire can trump published wet grip numbers on BRR... My opinion my change on this as I get more miles on the tire.
And back to the 111, I still see a pretty narrow use case for this tire personally. I'm not sure this will change either, as I'm not sure they're going to be able to produce a TT version of it.
cyclespeed
by cyclespeed
It's all gone a bit quiet here since the Aerocoach testing......
