Newmen Streem Vonoa 2024
Forum rules
GJK82
by GJK82
If it more comfy it does it mean it is less stiff than Bontrager
Mirco
by Mirco
Good Morning,
the wheels are are available for about 2-3 month 🧐 right now. So there might be not so many "long term experience" regarding the hubs/ bearings I think or does anyone already used them 5000km + ?
tommay
by tommay
+ 2 weeks, anyone with strong feelings towards the hubs? 🙃
Mirco wrote:
Sun Oct 13, 2024 8:51 am
Good Morning,
MichalGalocz
by MichalGalocz
tommay wrote:+ 2 weeks, anyone with strong feelings towards the hubs? Image
Good Morning,
the wheels are are available for about 2-3 month Image right now. So there might be not so many "long term experience" regarding the hubs/ bearings I think or does anyone already used them 5000km + ?
Nope, they feel fine after circa 3000km. Will see how they deal with crappier weather
tommay
by tommay
great, thx!
longjnes
by longjnes
After the rear , i got also the front one.
1067gr for the streem climbing 38/35 complete with rim tape. Very impressive!
pk0r
by pk0r
I have about 5,000km on mine and have been riding through quite some shitstorms as well.
Bearings are going as new, but admittedly I don't really think this reflects any special qualities after just two months of riding. For bearing life it is much worse when only riding once in a while, putting the bike away when wet in hot cellar or anything, not when using it on a daily basis.
I will swap the bearings to CS Coated ones next week or the week after and can then judge on the condition of the removed bearings.
Just for the record: The rear rim of the A.54 accumulated tons of water during a super rainy ride. It has a drain hole on the side but I never had such an amount of water on any wheel ever. The front did not have a single drop at the same time. Managed to remove the water through the drain hole on the side of the rim without removing tire or tape.
| works for an European bike manufacturer |
| Write less, ride more. |
Mirco
by Mirco
pk0r wrote:
Wed Oct 30, 2024 10:37 pm
Danke für die Info bzgl. der 5000km. Ja, sind am Ende 2-2,5 Monate, also noch kein Longrun.
tommay
by tommay
great to hear, thank you. more info would be nice later
rowdyyy
by rowdyyy
How easy is it to change the freehub from SRAM to Shimano? My local dealer has the SRAM rear wheel available at a decent price, but I need a Shimano one.
haublock
by haublock
Just pull off endcap and driver and push on the new one. The endcaps are tight though so might need pliers and a rag.
longjnes
by longjnes
bedampft wrote:
Fri Sep 20, 2024 9:07 pm
toxin wrote:
Fri Sep 20, 2024 8:27 pm
Inside
And to be more specific:
You need a hex key for the nipple, and a seperate spoke key to hold the aluminum fitting, that has the thread on it, of the spoke in place so it won't rotate and brake off.
hello, what hex key size is needed to adjust the internal nipple of vonoa spoke?
RDY
by RDY
I assume the freehwheel on these is the standard Newmen road one and completely interchangable? No adapters?
Kurt1980
by Kurt1980
RDY wrote:
Wed Nov 27, 2024 11:23 am
Email reply from R2 who state this Shimano freewheel fits the new wheels:
"Hello Kurt,
thank you for your inquiry. The following freehub body is compatible with the wheel:
https://r2-bike.com/NEWMEN-Freilaufkoer ... imano-Road
viele Grüße | best regards"
trex
by trex
Are the rims painted matte or is it raw carbon?
It looks like matte paint, doesn't it?
How does it behave in long-term use? Does it catch a lot of scratches?
