LB AR25 rims for all road biking
Forum rules
Pyotrump
by Pyotrump
AR25 rims (I asked for a fortified version. Each rim is 30g heavier than the original. 60g added in total.)
ID 24mm OD 29.2mm
paired with BItex 312hubs
: 1124g
R: Conti gp5K 25c clincher
F: Corsa speed G+ 2.0 25c tubeless
F: 18g sealant and 7g valve (There's no access hole so no need for tape)
R: Ridenow TPU 30g
Miscellaneous items..
Total: 2007g... oopsy slightly heavier than 2Kg..
Feels super nimble. At first I was so worried about its max pressure limit (28c 70psi, 25c 75psi) but all my worries were for the naught..
25c tires are 29.2~29.4mm when inflated @65psi
Ytse
by Ytse
Is it safe to ride 25c tyres on a rim with 24mm ID?
2020 Scott Addict RC / 2021 Trek Emonda SLR / 2023 Specialized Tarmac SL8
Aeo
by Aeo
These rims have a "mini-hook", so it's safer than on hookless rims, but I would say don't do it
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
Pyotrump
by Pyotrump
Ytse wrote:
Sun May 21, 2023 8:30 am
I think it is not... but LB said 25c is compatible with their product and there's no other option but to trust their words haha..
Pyotrump
by Pyotrump
Aeo wrote:
Sun May 21, 2023 10:59 pm
Yes indeed.. I know that it is risky but can not help but choose 25c for weightweeniesm. I just get relieved by the fact that those rubbers are slightly fatter (29.2~29.5mm) than the rim (29.2)
kode54
by kode54
Yes...its a hybrid hook/hookless design. I think this is a nice inbetween for those that are concerned about hookless and tires blowing out.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
gshb
by gshb
Just curious why you use clincher for rear and tubeless for front? I did ask LB if clincher can be used on AR25 with mini hook (or hybrid hook) and they said yes, despite GP5k saying on the tire itself it must mount to hooked rims.
Pyotrump
by Pyotrump
gshb wrote:Just curious why you use clincher for rear and tubeless for front? I did ask LB if clincher can be used on AR25 with mini hook (or hybrid hook) and they said yes, despite GP5k saying on the tire itself it must mount to hooked rims.
There's no specific reason. That was just because I have them..
At first, I mounted pro one tl laying around but found that was leaky so swapped it with 5k, which was also laying around in my house.
나의 SM-G977N 의 Tapatalk에서 보냄
eucalyptus
by eucalyptus
Fortified version in this case means reinforced rims? Are they reinforced over the regular rims or just standard rims and you did not choose flyweight option? Interesting what your body weight is hence the fortified rims.
Pyotrump
by Pyotrump
eucalyptus wrote:Fortified version in this case means reinforced rims? Are they reinforced over the regular rims or just standard rims and you did not choose flyweight option? Interesting what your body weight is hence the fortified rims.
There' no "Flyweight" option for AR25, IMO LB provides those rims with flyweight option as default. I asked for a fortified (in other cases like ar 45 "Default" option) version and LB asked back "how much fortification are you looking for?"
Then I said that I am a 80+kg rider and going to use the wheelset at harsh gravel course. Lb suggested 30g addional carbon layup.
