Best Tubular for Training (2023)
Forum rules
aeroberg
by aeroberg
Got a bike that came with Campagnolo Bora Ultra 50mm Tubular and want to use them this winter. Looking for the best tubular tires to train through winter base training (Southern Hemisphere winter, no snow, ice, dry but dark at 5am).
These are my requirements what I am looking for
- 28mm tubular (rules out Continentals)
- Puncture Resistant
- Durable 3000-5000km (Average about 1000km a month and ideally want it to last 4-5 months)
- Tan wall
Durability and Puncture Resistance is the most important. I have narrowed down to a few options
- Velofelx Pro Gum Sidewall 28mm
- Tufo Hi-Composite Carbon 28mm
- Vittoria Corsa Control Graphene 2.0 28mm - (not sure about durability)
- Challenge Paris Roubaix/Strada 28mm
Will move to a Vittoria Corsa for race season after
Which one do you suggest or any others you can think of?
jlok
by jlok
In my experience Corsa Control G2.0 is better than Challenge. My Challenge Seta Ultra 27mm measured 26.5 at best, easy puncher, and somewhat irrlevant, very slippery when wet. Wheelset is Bora One 35 DB Tubular.
mrlobber
by mrlobber
Specialized Hell of the North 28mm tubular.
Got almost 7k km out of the rear before it was destroyed in a crash (but it had sealant already inside to seal one puncture, though). The front is still good.
From the options you listed... a toss between Vittoria and Veloflex, I suspect Vittoria could be more durable and definitely better grip.
aeroberg
by aeroberg
mrlobber wrote:
Mon Mar 20, 2023 12:47 pm
Wow the Specialized Hell of the North looks good. Hopefully they have it in my country. I see it for $100 on the Specialized website
aeroberg
by aeroberg
Anyone know what mileage can one expect from the Vittoria Control?
LouisN
by LouisN
FWIW:
I ride almost exclusively on tubulars (95%+ of the km's).
I've been for more than 15 years.
Spring and fall in Canada have their downsides, as the poor quality of the tarmac.
My best training tubulars have always been my best tubulars: Conti Comps 25 mm, or Veloflex Pro Tour (available in 28 mm).
Everytime I wanted to try some "training" tubular (Vittoria Control, Vittoria Rubino Pro G+), they never lasted as long as a good tubular. With the exceptiion of Conti Sprinter 25 mm (not the gator version). These things last forever.
NOTE **: Punture resistant is not something that actually exists. Just thicker rubbar on the rolling band, or some fabric under the casing. But very often it stiffens the tub, and ends up being more prone to cuts. So for me the more supple the tubular, with the right pressure, does it.
My daughter was riding and racing in the Netherlands last year. Lots of pouring rain races on tough terrain, cobbles, etc... She puntured a few times, but had good luck and durability with S-Works Cotton 28 mm tubulars.
NOTE2: I added some latex sealant (Fast Cure Seam Sealant) on the orange sidewalls of the Veloflex Pro Tour, they keep their good looks for much longer.
Louis :)
Mcdeez
by Mcdeez
How you guys deal with flats on tubulars?
Im scared of buying tubulars because im not sure its that easy to fix
Sent from my Pixel 6 Pro using Tapatalk
Kayrehn
by Kayrehn
Very small bottle of orange sealant for me. When punctured, remove valve core, pour in sealant, rotate, inflate half and wait a while for it to work. Please do not rip off your tubular and dump it immediately with small punctures!
Sent from my Pixel 6 using Tapatalk
jlok
by jlok
I'd like to understand how the sealant works. Does it seal the latex tube or the whole casing? I tried that with my Corsa Control 1st gen but didn't work.
Kayrehn
by Kayrehn
It seals the latex inner, the outer casing is fine with puncture holes usually if they are tiny. Sometimes it needs a longer time to cure. There are numerous times when I have a puncture and it didn't seal within half an hour but overnight it was fine again and I could use it normally
Mcdeez
by Mcdeez
Kayrehn wrote:It seals the latex inner, the outer casing is fine with puncture holes usually if they are tiny. Sometimes it needs a longer time to cure. There are numerous times when I have a puncture and it didn't seal within half an hour but overnight it was fine again and I could use it normally
Ok,thanks
But on the road, it take long to seal i guess
aeroberg
by aeroberg
Would I be correct to say that 28mm tubular tyres have a higher chance of sealing with preventitive sealant as you running lower pressure?
LouisN
by LouisN
Some "new" members to tubulars would be advised to read the tubular thread. A gold mine of information on everything there is to know.
Like the following principle for example: Never use sealant in a tubular tire BEFORE a flat. Unless you are in a bike event.
Louis :)
