Want a set of wheels specifically for Raid Pyrenees
Forum rules
Hi guys
As the title suggests, I'm attempting raid pryrenees with a group of friends later in the year (supported), and I'm thinking new wheels. For the last few year I've taken my lightweights to France on my cycle trips. But that was on the premise that if it did rain heavily one day I'd just bail and have a day off the bike maybe. This time I don't have that option so I need a tubular rim break wheelset with better braking in the wet.
Would a set of Bora 35 Ultras do the job? Im a bit out of the loop in terms of the latest and greatest brake tracks...
- MrCurrieinahurry
- Moderator
Maybe a stupid question but if it's a supported event could you take a second wheelset with you just in case?
Personally I'd go for an alloy brake track if specifically for descending in the rain.
Basso Diamante eps 12
The latest and greatest brake tracks have been minimised to an ultra-compact form factor located on the left-hand side of the hub. It's remarkable really. You should investigate.TurboTommy wrote: ↑Sun Mar 12, 2023 6:21 pmIm a bit out of the loop in terms of the latest and greatest brake tracks...
cycling / nature / music
- MrCurrieinahurry
- Moderator
Miller don't start this please
Anything decent with a grooved brake track will do the job. Just take some spare brake pads as they will get chewed up fast on the grooved track. Campy wheels will work just fine.
BUT, to repeat myself, this works if you are light, but can be a problem if you are bigger. In that case alloy is the only safe bet. Depending on which descents are used, the brakes may not be too stressed. Some others though, may require you to "hold" the bike quite a bit. Worth researching the exact route carefully.
Sorry. Sometimes the jokes write themselves.
