Wheels Lab Tests
Forum rules
C36
by C36
rudye9mr wrote:See elite wheels have carbon spokes. Not sure if they sell separately but a review of rim had off centered drillings in rim bed for a better alignment of the carbon spokes.
Might be worth checking the meta for using carbon spokes.
The dyneema/Berd are another option too..
Side note since dyneema is mentioned. It’s a strong (high resistance to traction) but not very stiff (elongate under traction) fiber. Has interesting properties for vibration absorption like in mtb but on our road application the only example I have seen on a lab was a noodle.
alanyu
by alanyu
Can you label which wheel is tested by which lab?
Unless there are some crossover data with different labs, I wouldn't compare the numbers directly from different source, since the protocal/method can be different. Even with the same protocal/method, the number can be slightly different due to the calibration of the device from different labs.
lemos
by lemos
any chance you can place the spreadsheet on a read-only shared Google Drive, or something? just so we can use it, and play with it?
C36
by C36
alanyu wrote:Can you label which wheel is tested by which lab?
The stiffness numbers are comparable. A dozen wheels have been tested on different sources with good match. Usually within 1N/mm. Some questionable sources I have (either web or from manufacturers are not displayed and they do show odd numbers).
On inertia I can’t mix results so when presented they are from the same source. They measure an energie but don’t know the acceleration profile selected so couldn’t find a correlation.
Same goes for aero I only show Tour sources so far.
HBike
by HBike
Bontrager RSL
C36
by C36
Update with few interesting wheels
- Princeton 3532: great example of the difficulties to be extremely light and preserve reasonable stiffness (the 28 spokes version can only be better and recomended). Worth notice it's slightly flexier than the One-K RD Ultimate and yet 200g heavier.
- Black Inc 5 spokes: often seen as a good option (monoblock frames = stiff, so for wheels should be the same no?) but shows that like 20+ years ago (Mavic 3G), 15 y (Xentis) and now Black inc that it's difficult to make them stiff and reasonably light (and those last ones are likely not very aero either).
- SES 4.5: kind of highlight what I never understood... they have been good from aero standpoint but on the rest, they are very average wheels, not really light, not really stiff.
- 3 heavier mid range wheels, Shimano Ultegra, Bontrager RSL and Hollowgram 35.
Looking forward adding the Hyperon and the latest Syncros and see how they compete with the Ultimate.
Graph after the break
C36
by C36
First able: absolute numbers
second table: relative performance compared to best in class
New wheels highlighted in blue
Same same but different, for bars-chart fans
Yoln
by Yoln
Is there any ways to have some standard Lightbicycle data (AR45 with CX-ray and dt-240; and the same with carbon spokes)? I have never seen lightbicycle data for lateral stifness and aeroness
#RETIRED# Lynskey “the Do-it-all Helix” 🧬:https://tinyurl.com/bdmb5y24
ichobi
by ichobi
Relatively speaking, what effect do low stiffness wheels have on your riding performance and characteristics? Like less confidence in turning downhill corner? Do they matter much? For example a bb stiffness test anything more than 60n/m doesn’t really give a performance edge. You won’t feel it.
It’s surprising to me that expensive wheels have low relative stiffness compared to the rest of the charts like the enve 4.5 and princeton. I rode good (green) stiffness wheels like the dt 1100 50 and it doesn’t act like a shallow wheels that accelerate well and feel reactive (duh they are still 50mm deep) despite the “good” stiffness. On the other hand the black inc five wheels while not topping the stiffness chart gives me absolute planted feel on the descent - feeling that i cant quantify but i haven’t found this feeling on other wheels either.
Jaisen
by Jaisen
ichobi wrote:
Sun Aug 13, 2023 4:56 pm
It’s surprising to me that expensive wheels have low relative stiffness compared to the rest of the charts like the enve 4.5 and princeton. I rode good (green) stiffness wheels like the dt 1100 50 and it doesn’t act like a shallow wheels that accelerates well and feel reative (duh) despite the “good” stiffness. On the other hand the black inc five wheels while not topping the stiffness chart gives me absolute planted feel on the descent - feeling that i cant quantify but i haven’t found this feeling on other wheels either.
Also what exactly do these stiffness tests measure? Are we talking about torsional, radial, lateral stiffness? Is the number above an average of them somehow? It seems to me if the wheel has high lateral stiffness but isn't rated that highly in radial stiffness that might be a good thing, it will feel less harsh while still performing quite well where it matters.
C36
by C36
Yoln wrote:
Thu Aug 10, 2023 4:35 pm
I am not aware such a data exist. Hunt did a speech in Bikerumors around the benefit of their Carbon spokes (https://bikerumor.com/spotted-hunt-prot ... de-france/) with 6% stiffness despite 16% spokes less, so that could translate to 27% more stiffness all things equal (but cause their SS wheels are really flexy and cut spokes count, their carbon spoked just became "normal").
Low lateral stiffness will impact cornering and performance out of the saddle on two aspects: better efficiency when out of the sadle and higher max power linked to better biomecanical efficiency. On top of my head at 57-60N/mm there was no more measurable differences (and 40 was considered as relatively low).
Now you mention acceleration "feeling". Inertia has this funny that you can feel it wayyyyyyy more than it impacts measurable performance (that on a full 200m acceleration from 0 to top speed translate into 1 or 2 mm of gain), and it will be completely outweighted by stiffness impact.
For the Black Inc Five, this wheel construction use to give a different ride feel. The spokes work in compression and they usually come with higher vertical stiffness .
Yoln
by Yoln
C36 wrote:
Fri Aug 04, 2023 12:19 pm
Do you know which combination of spokes and hub was used for the Princeton 3532?
ichobi
by ichobi
Thx c36 for the explanation. Yeah i do agree that in the end “slow” acceleration feeling from hight depth wheel doesn’t meaningfully impact performance all that much but do have high psychological cost.
However, the interesting case to me from these dataset are for the shallow carbon wheels. Do we also conflate low relative weight (12xxg),which equals to quick acceleration (low inertia feeling), with lateral stiffness? I.e they are not measurably stiff but give you the perception of having high stiffness just because they are light?
If this is the case then the low lateral stiffness wheels like the princeton should feel drastically different from wheels like Cadex where it’s both laterally stiff and also very light.
For example i used to ride the roval clx 32 , a generation before the Alpinist clx and clx ii and i can tell they are not that laterally stiff, compared to say a pair of Lightweights. They are not comparably sharp in the corner but they are alright. But they are light so they are easy to spin up. They are fun to ride around. But i could imagine if they are built laterally stiffer they could feel very spritely and “flippable”.
C36
by C36
24 spokes (need to confirm if CxRay or even a lighter version) and their Tactic hubs.
Yoln
by Yoln
Yeah, I would guess by the weight given (1155g) that it's the CX-ray indeed and not the CX-super version.
Still, not too surprising results given it's a 24h with featherlight rims and lightweight spokes.
Given the fairly wide flange distance and pitch circle diameter of the tactic hubs vs their dt-Swiss counterparts, I would expect the dt-240 version to be both heavier and less stiff, no?
