New Vittoria Corsa Pro!!
Forum rules
skinnybex
by skinnybex
FlatlandClimber wrote:
Tue May 30, 2023 11:56 am
gorkypl wrote:
Tue May 30, 2023 10:53 am
Aerodynamik wrote:
Sat May 27, 2023 10:45 am
Does anybody know whether they will offer a black tyre as well? Not a big fan of tan walls on my bike.
+1
Also - any idea when the bicyclerollingresistance.com will test these?
Number 1 voted tire in May. So probably early June. But we know it's fast already. Now it's only about grip and puncture resistance.
I'm so happy with my Corsa Pro 28mm after 200 miles that I ordered a pair of Corsa Pro Control 28mm for another wheelset to do a comparison. I own 6 road wheelsets with various tire combinations and I also did about 300 miles on the 28mm GP5k TR S in-between the rides on the Corsa Pro just to A-B these two tires. I much prefer the Pro for road feel and it feels darn near identical in perceived rolling resistance. Looking forward to see the punture data from BRR
23’ Cervelo Soloist / 6.88kg - 1x Crit Bike
22' Cervelo R5 / 6.35kg - Climbing Bike
22' Cervelo Caledonia 5 / 7.55kg - Travel Bike
21' Cervelo Aspero / 8.06kg - Gravel Travel Bike
23' Cervelo Aspero 5 / 8.25kg - Gravel Race Bike
bobones
by bobones
bobones wrote:
Wed May 17, 2023 11:17 am
What size would work best with 19 mm internal 26-27 external wheels like Bora WTO? I'm thinking any of 24, 26, or 28 with 24 best for 105% rule and weight, 28 for running at lower pressures, with perhaps 26 the sweetspot as long as they don't blow up bigger than labelled. The 25 mm GP 5000 S TRs I have mounted have remained true to size after many months of riding (sub 26 on the WTOs) and it looks like these VCPs are if anything a little smaller?
So I ended up buying a 24 mm for the front and a 26 for the rear. The 24 weighed 262 g and the 28 was 279 g. They do come up smaller that GP5000 S TRs, with the 24 having WAM 24.2 mm, and the 26, 25.7 on 19 mm internal at 80 psi.
They look dreamy in tan, and the ride is sublime with no hint of the hardness or harshness that I can feel on the Contis at 80 psi (I usually ride them at 70 psi to counter this).
I've got a 150 mile ride with 10k ft of elevation tomorrow and think I'm going to opt for these on 50 mm rims over the Power Cup 25s (WAM 27.7 mm on 19 int) on 38s, although it's a tough call as the 50s should be much more aero but a good bit heavier than the 38s.
MarkoP
by MarkoP
Sorry if I missed this but when will they be widely available? I'd like to purchase them in 700 x 28 tubeless with tan walls...in Canada. Thanks!
Current: 2021 Bianchi Specialissima I 2021 Tarmac SL6 S-Works (Sagan Edition) l 2023 Aethos S-Works
Aryeh
by Aryeh
MarkoP wrote:Sorry if I missed this but when will they be widely available? I'd like to purchase them in 700 x 28 tubeless with tan walls...in Canada. Thanks!
I ordered mine directly from Vittoria's website.
MarkoP
by MarkoP
Aryeh wrote:
Tue May 30, 2023 7:55 pm
Ah, gotcha. Much appreciated.
Edit - for those interested, I contacted the Canadian distributor and they'll be available in stores (Canada) as of July 1.
FlatlandClimber
by FlatlandClimber
What's the magic with these? I've ridden cottons before but these are crazy plush! I've re-checked tire pressure twice during the ride, because they felt so smooth, that I was scared they had dropped significantly in pressure. Seems to be the construction though.
And they look great too:
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
BigBoyND
by BigBoyND
Wed May 31, 2023 7:04 am
... I've re-checked tire pressure twice during the ride, because they felt so smooth, that I was scared they had dropped significantly in pressure. ...
I had this experience with the Power Cup coming from GP5k.
How does the Vittoria compare to Power Cup in terms of supple ride feeling?
e4rthm0ver
by e4rthm0ver
I have set of Corsa Pro Control 28C on it’s way to me. I’ll post weights and measurements of them mounted on 22mm inner width DT Swiss ERC1100 wheels tomorrow
LedZeppelin007
by LedZeppelin007
I also worried I was going flat because they are so forgiving. Really nice tire so far.
polpy
by polpy
Brr results for 28mm are online. Looks promising but seems to have the same issue like the michelin with tread width being too small for modern wide rim.
CyclingGiraffe
by CyclingGiraffe
polpy wrote:
Wed May 31, 2023 8:32 pm
This is strange to me, particularly since we know that these tires (the new Vittoria) are raced (successfully) at the very highest levels of the sport, including races as diverse as Paris-Roubaix and the Giro. Is the tread too narrow for those ProTour riders? For weekend warriors like me? For a rolling steel drum? I'm not being facetious; I am genuinely curious as these Vittoria tires look very promising to me.
fizzaz
by fizzaz
CyclingGiraffe wrote:
Wed May 31, 2023 9:18 pm
Remember when the conspiracy theories were flying about these tires and flats at the classics? Looks like this might be why. My guess is they are great until they aren't. Jumbo Visma were on reserve wheels that are very wide and they seemed to have the most trouble. An issue like this would probably only show up in races like the classics.
LedZeppelin007
by LedZeppelin007
Are we referring to the same Jumbo that managed to have a 1x SRAM equipped bike with a clutch drop a chain on an uphill time trial?
HBike
by HBike
fizzaz wrote:
Wed May 31, 2023 9:49 pm
Mathew van der Poel didn't have big problems, right? Alpecin-Deceuninck, Lotto Dstny, EF Education - Easypost, Astana Qazaqstan Team, Eolo Kometa all use Vittoria aside from Jumbo. Did they all have trouble or using different tires?
fizzaz
by fizzaz
HBike wrote:
Wed May 31, 2023 11:14 pm
Sometimes, I swear. A few of the teams did have troubles, yes. From memory it was the teams that all had wide wheels.
