Disk brake wheelset
Forum rules
godspeed
by godspeed
Hello there !
Iam searching for new wheels and need info about wheels spec - what i need - what i will buy .
I need hub with better rolling resistance - for climbing - disk brake - 23mm tyre .
My current entry wheels . fulcrum 600db . disk brake - centerlock.
It says : rim width 25mm - inner rim width 20mm - rim height 24mm .
I will spend 500 euro . it worth the upgrade / i will mention any obvious difference or should spend more?
Thx in advance !
jch3n
by jch3n
500 eur won't get you anything much better than the Fulcrums you currently have. Definitely consider spending more.
dirks
by dirks
I am in the same boat as OP. My wheelset is a Fulcrum 600 aswell, with 10k KM on them and recently the third spoke on the rear wheel broke. From what I have read so far is, that after the 3rd strike, you should consider relacing the wheel or buy a new set.
I m thinking 500€ too, like Fulcrum 3, Campagnolo Zonda or DT Swiss (1400 if I stretch my budget).
You think that makes no sense? I m an endurance rider and I dont care about aero or weight. I just like to upgrade to a nicer set.
