TL tire popping into the rim bed, dangerous?
Forum rules
Hey everyone,
I have a set of relatively narrow TT wheels (18.8mm internal, hooked) that I have set up tubelessly with TT tires.
When the air pressure gets super low, the tires pop off the bead, and into the rim bed.
I've tried three different tires (GP 5000s TR, GP5000 TT and Vittoria Corsa Speed), the standard single wrapping (factory installed tape), double wrapping and triple wrapping. Nothing seems to help.
The tire goes onto the rim relatively easily, but doesnt sit stupidly loose or can be removed easily by hand.
I've tried fitting a Vittoria tire liner in the smallest size, but even that was too big to get it fitted.
So, what can I do, and is this really dangerous? Riding on a fully deflated tire would be dangerous either way, so is this a thing I really need to fix?
If so, what do I need to do?
Thanks in advance.
Thanks in advance.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
The main problem is if the tire unseats in the middle of a ride, then a minipump will not be able to reseat it. You’d need to have CO2 or insert a tube.
Last edited by TobinHatesYou on Mon Dec 19, 2022 4:52 pm, edited 2 times in total.
That's a good point. That wouldn't be that much of an issue for me though.
I rode wheels like that for ages, in fact I have a pair of wheels where the tyres still do that, so I am in the 'annoying but not dangerous' camp. As noted, the issue is how to reseat the tyres mid-ride should that be necessary.
cycling / nature / music
Cheers. I got the same reply from the manufacturer. These are mainly race day wheels anyway, so probably no harm in any of that.
I don't know if "tubeless compatible" constitutes "the tire doesn't unseat when at low or no air pressure". I literally don't know... all the other aspects of TL compatibility work though.
Basically the question of this thread is: "why wouldn't you?"
+1
It's somehow indicates how easy the tubeless tire would burb. Scary stuff if you experienced it, which most likely would be followed by a crash.
As the tyres are going into the rim bed, that would suggest that there's no bead lock in your rims which is there to prevent this very thing happening.
As mentioned by others, this will increase the chance of the tyre burping and a blowout occuring if you had a puncture.
I may be being overly cautious but I'd run those wheels with tubes. I know that every watt matters when it comes to TT bikes but a latex tube set up isn't really any slower than a tubeless one.
Pretty much every Roval road wheel before the Rapide/Alpinist generation were like this and they didn’t burp any more than other wheels…that I know of. Meanwhile I have seen certain tires release air/sealant even at 50psi just by squeezing the sidewalls with hand pressure.
Hopefully the etrto standard will make these sort of issues less likely going forward. A uniform sizing system adopted as a standard should make tyres and wheels more compatible.
Loving road tubeless and sticking with it anyway. No desire to go back to tubes or worse still, singles.
