-Hooked to run clinchers
-About 50 mm depth (give or take roughly 5 mm)
-Over 27 mm wide
-1500 gram range
-Disc brakes
-DT hubs
I know I have a lot of options with this list but I want to see if anyone can add what they know so I can see if there's any wheels I haven't seen yet.
Looking for a wheelset
Forum rules
Roval Rapide CL is one of the best money can buy. A little over 1500grams but bulletproof.
Tarmac SL8 Maganta Gold
Crux Green Pearl
Previous bikes:
Crux Forest Green
Tarmac SL7 Snake Eye
Venge Bora Team
Venge Purple
Trek Madone SLR 7
Crux Green Pearl
Previous bikes:
Crux Forest Green
Venge Bora Team
Venge Purple
Trek Madone SLR 7
- AscentBikes
- in the industry
- Contact:
A little under your depth spec, but if you want a high performance wheel, consider the Ascent Polaris 42.
1300 grams with DT 240
32.5mm wide, 23mm internal width.
Hooked, able to run clincher and tubeless
Tested in wind tunnel, best with Vittoria Corsa Next 28 and 32mm tires.
Lifetime warranty and parts crash replacement for original owner.
Clearly Ascent needs a medium-deep 56mm Polaris in the vicinity of 1400g.
