I agree. I did order a set of 6.7s since I have 3.4 AR, 4.5 AR and 5.6 SES. They will replace the 5.6...since I enjoy the wider width (maybe not as wide as the new 3.4 or 4.5, but wider than the current 5.6 that I have).TobinHatesYou wrote: ↑Thu Jul 21, 2022 8:16 pmI live at the top of a 15% grade and no way am I buying 2.3s just to be faster for that 5 minutes or so on the way home only to be slower during the rest of the ride. These wheels have basically one purpose, very steep hill climb races or mountaintop finishes.
ENVE Refresh?
Forum rules
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
New 3.4 are 4.5 are identical to 3.4AR and 4.5AR that you already have. And you say you don't want to be as wide... as two pairs that you already own?
His: Orbea Orca OMX
probably refering to internal.. which in my case 5.6 @ 20/19.. I'll take the 6.7 @ 23 internal
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
Lifetime warranty aswell, since enve has reduced there warranty...LedZeppelin007 wrote: ↑Fri Jul 22, 2022 2:28 pmAny benefit in looking at Zipp 353s?
I''m keeping 3.4AR and 4.5AR. Replacing older narrow internal width 5.6 SES with the 6.7.
- Factor LS Disc
- Factor LS Disc
Correct on all accounts!spdntrxi wrote: ↑Fri Jul 22, 2022 6:39 pmprobably refering to internal.. which in my case 5.6 @ 20/19.. I'll take the 6.7 @ 23 internal
- Factor LS Disc
- Factor LS Disc
I will never buy another Enve product again. Bought my second pair after returning the first due to a very long list of QC problems (big piece of silicon in the rim, permanent marker spots on the rim meant for decal placement, and the rear wheel just wouldn’t hold air over the course of long rides).
Got some new ones, set them up. Seemed to be a small bit of debris rolling around in the rear rim. Followed religiously Enve’s taping guide. And, won’t hold air. No matter what I do, how much sealant I use, they won’t hold air during a ride. I have been reinflating, trying some new things, and then the front wheel just exploded during inflation. Complete side delaminating blow out.
I just want to comfortably ride my bike. This is insane and I just want my money back and not have to deal with this ever again.
I think so. But I had an o ring on there and the TyreWiz. But, Jesus, what a catastrophe.spdntrxi wrote:WOW .. did you use there little special valve thingy
This is exactly why Campy's design of a carbon rim bed is superior. Seems like Enve needs a little more time on QC and a lot less time on instagram.
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
you think ? it's kinda why they require it for that specific reason ?LedZeppelin007 wrote: ↑Sun Aug 21, 2022 7:12 pmI think so. But I had an o ring on there and the TyreWiz. But, Jesus, what a catastrophe.spdntrxi wrote:WOW .. did you use there little special valve thingy
Cant tell if those are new or old rims.. sticker is too OOF. Anyways yes golden opportunity missed by enve to put a hole in all their new rims.
2023 Pivot E-Vault
2023 Pivot E-Vault
I bought ENVEs because they had the best warranty in 2017. They still had the best warranty in 2021, but not anymore. IMO Bontrager offers the best balance between rim dimensions and weight while also remaining hooked. Light Bicycle is also in the conversation.
Brand new 4.5s.spdntrxi wrote:you think ? it's kinda why they require it for that specific reason ?LedZeppelin007 wrote: ↑Sun Aug 21, 2022 7:12 pmI think so. But I had an o ring on there and the TyreWiz. But, Jesus, what a catastrophe.spdntrxi wrote:WOW .. did you use there little special valve thingy
