It's not necessarily about just cornering on it. Road debris is much more likely to slash the sideweall even when not leaning right over.naavt wrote: ↑Mon Feb 27, 2023 1:41 pmMines are much worse than that. I'll take a pic today when at home, but until now I've been descending with confidence. It seems to me that you have to corner with your knee on the floor to reach that sidewall on the tire. I really don't see anyone leaning that far on a road bike.
New Michelin Power Cup Tubeless: GP5K S TR competitor
Forum rules
Go back to page 26 of this thread to see how easy it is to lean past the tread on a Power Cup. The cornering grip is great until it isn’t. I definitely fell my rear tire start to go at a flat crit once enough of the rubber had worn off the sidewalls.
No, it's significantly wider. That's also what Jarno said in the BRR review. Along the lines of: "If only they had copied the TT for width..."
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Still think the tread story has been exaggerated. I could imagine if you ride on terrible roads like Tobin, you may want more side protection but on 10s of thousands of km the CIC U Nantes Atlantique (pro Continental) had no issues on training or race situations. Now they use 25 and 28mm section on either Shimano (21int-28ext) or Winspace (21-27.6) so tires are not as stretched than on 24mm internal.
Statistically it’sa lot more meaningful that my personal case where my 23 (tube type, measuring 25 mounted) and 25 (TL, 27 mounted) don’t display any sidewall wear.
My tires didn’t get destroyed from rough roads. They got destroyed in 2-3 races from hard cornering. 25mm on Aeolus RSL 37 wheels (21mm.)
Then, not sure what you are doing differently than Pro and Espoir riders, the only thing I see, would be installing them on much wider rims than the 21mm they use, I would be surprise the relatively lower pressure you use generates enough deflection to expose the sides.
Edit: I had another look at your tire pics and there is clearly something but I have never seen so many cuts on the edge of a tread, at least not on the countries I ride or followed riders. If the sidewalls, that have no protection, were really that often in contact with the road, they would be distroyed.
I'm french so Corima wheels have always been a dream for me
I just picked a Paire of WS58 Dx and put Michelins on them since I had a pair and never mounted them because of the narrowness of the rolling strip
I get why U Nantes Atlantique never had a problem, Corimas are 16C internal so the rolling strip is comparable to a GP5K, they measure exactly 26mm
On my old Chinese carbon wheels (Farsports Revo) they ballooned to 28mm and were completely stretched out
No doubt a silly question, but given the 23mm clincher measures up as circa 25mm on a 20/21 ID rim, is there another reason you shouldn't use the 23mm on a reasonably wide internal rimmed wheelset (I'm thinking safety, or do the 23s have even less tread coverage? Would this combination be even worse for sidewall damage)? I have Roval Rapide CLXs (21mm internal) and Extralite C338s (19mm internal), and was pondering the 23mm clinchers to try and keep the inflated width within the 105 rule. Don't want to pull the trigger if there would otherwise be a reason that this combination would be a daft idea however... Cheers, DaveC36 wrote: ↑Thu Dec 01, 2022 10:55 pmOn a 19mm rim they measure 25.1/25.3maxima wrote:I would like to knows anyone running 23mm Michelin power cup on their TT bikes? What real life width will that be on a 20mm inner width rim? if the 25mm measure up to 28-29mm ..............wonder the 23mm will measure 26-27mm easily
After 3000km they must be a bit wider, can check if interested.
Just fit a set of the 28mm version on 21mm internal rims and they're measuring at 29-29.5mm depending on pressure (65-72psi). So nothing shocking really in terms of ballooning way over the labeled size.
Will be keeping an eye on if I get unusual wear on the sidewalls due to the narrower tread, however it does seem like quite the lean required to get there on the 28.
