New Michelin Power Cup Tubeless: GP5K S TR competitor
Forum rules
Finally installed my power cups (28mm).. 3k miles on the 5000sTR and rode through a field of glass on the weekend so it was time.
Went on without a hitch but failed at the AirLiner install (again).. too much faff to worry about it. Hopefully they will feel great at the wednesday night practice crit.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
me too, altough they are overall also very good tires. But the PowerCups and Corsa Pro just feel much better.
Colnago C68- Enve SES 4.5
S-Works Aethos - Enve SES 2.3
Open MIN.D - Enve SES AR 4.5
Mosaic GT2-45 - Enve SES AR 3.4
Open WI.DE - no money for Enve
Puncture resistance on the center tread of a tubeless tire is a red herring IMO. I’ve only had problems with two tires, the Corsa Speeds and the Pro One TTs. I’ve never had puncture problems with GP5K S TRs. Sealant generally does its job.
Sidewall durability is more important as is tread coverage.
I would always choose 28mm - we are not in 2015
that is the only place I get punctures (center).. I have had no sidewall issues since turbo cotton days.TobinHatesYou wrote: ↑Tue Jun 06, 2023 9:21 pmPuncture resistance on the center tread of a tubeless tire is a red herring IMO. I’ve only had problems with two tires, the Corsa Speeds and the Pro One TTs. I’ve never had puncture problems with GP5K S TRs. Sealant generally does its job.
2023 Pivot E-Vault
2023 Pivot E-Vault
I have 28 mm on a second set of wheels but I like 25 mm on the set I'm using mostly now for criterium/granfondo.
My only concern was about puncture, is there any difference between 25 and 28 considering the tread?
I like em... like em better then 5000STR's.. plush and just as fast. I'll take a good look at the tread tomorow in the light after tonight practice crit.
2023 Pivot E-Vault
2023 Pivot E-Vault
actually no... Sean / Adam then Fun Ghi. 3 man break. I got dropped as usual, but it's all good. Winds were something else.
It's fun racing well above your Cat and trying to hang on.
2023 Pivot E-Vault
2023 Pivot E-Vault
after a few days and ~100mi. Still plush ride.
Crit,and a couple punchy group rides.
No discoloration due to orange seal
but they do lose a little psi sitting around
Wheelset Enve 6.7
F: 31.27mm 63psi
R: 31.31mm.66psi
Wheelset Enve 6.7
F: 31.27mm 63psi
R: 31.31mm.66psi
2023 Pivot E-Vault
2023 Pivot E-Vault
You are running a 28 mm tyre on a 23 mm internal rim, right?
Still confused about BRR side thread warning but want to try Michelin on Reserve wheels (23/22 internal) instead of the usual GP 5000 S TR.
correct 28mm tire on 23mm internal rim. I've done 1 crit, but surface is good on the practice course, so I dont worry too much.
2023 Pivot E-Vault
2023 Pivot E-Vault
