DT Swiss DICUT DB - New wheels
Forum rules
Does anyone have information on the er 1400 dicut hub weights? I believe they're based on the 240 non exp hubs but with ceramic bearings. I'm trying to find the weight of these hubs or the weight of the non exp 240 hubs but can't seem to locate this info.
I'm looking to buy a used pair of these wheels for about $400 CAD. Will probably use it this year as my road wheels and then rebuild it with some light bicycle rims. Main issue would be ordering the special T shape spokes directly from DT.
probably just when they get notchy. have to take the endcaps off and run them with your finger. i wouldn't spend on OEM bearings, would just go aftermarket. good japanese steel or if you're brave, chinese ceramic from boca bearing out of florida. i've had good luck with the bocas on road bikes, got a bad one that got pitted (albeit under too much preload...sometimes DT Swiss gets their seat depths wrong) on the rear DS of a MTB.
I pulled the trigger on some Arc 1100 50s. 85kgs....wish me luck. i wanted to go with another set of cosmic SLR bc i love the tapeless FORE rims and the ratchet FH system that doesnt cover the DS bearing (meaning you can pull the bearing without a trip to the bench vise to back out the drive ring), but alas it seems Mavic support in USA is next to non-existent. It's a really good product, just...conservative.
so DTSwiss it is. I hope the NDS bearing doesn't walk like the MTB hub i had (literally no NDS bearing seat) and i hope theres no windup. i like they build with aerocomps on the DS side. stoked on the rim profile and stoked they didnt chase the 25ID bandwagon. looks a little like the Reynolds/LEW blacklable profile, but without quite so acute of an edge at the spoke bed.
i don't see what can be improved:
DT240 hubs are a standard
24 DT Swiss spokes and nipples are also common
the rims of the ER1400 and PR1600 are low profile wide alloy rims; Not much to improve there.
looks like the new er1400 dicut has gain about 100g (~1600g vs ~1500g) compared to the previous version. Also my understanding was the previous dicut version came with ceramic bearing (spline did not) vs the current dicut comes with steel bearings. Makes it a bit complicated because i thought "dicut" was how DT would let the consumer know it came with ceramic bearings
Debating getting the Hadron 625 as Swisside has a solid discount going right now.
Any idea when these wheels will be updated again? Would be bummed if i start riding them next season and they get updated just a few months later.
It's too bad there's no update to the rim brake OXIC wheels. The only 'new' rim brake offering is the P1800 which appears to use the old 18mm wide rim. I'm happy the OXICs haven't been completely phased out, but it would have been nice to see a refresh with wider rims on these otherwise brilliant wheels.
How do I know if I have the EXP hubs? I've just purchased a brand new GRC 1400 wheelset, but it doesn't state EXP anywhere. Does DT still produce the older style 240 hubs and does this affect the freehub body required?
Also, I can't seem to find any CL lockrings. Aren't these included with the wheels? Neither are they included with the new AXS groupset's rotors.
