Pirelli P Zero TLR tubeless
Forum rules
TobinHatesYou
by TobinHatesYou
warthog101 wrote:
Sat Apr 22, 2023 9:42 am
Is there a newer etrto standard than this?
Yes.
wickedstealthy
by wickedstealthy
TobinHatesYou wrote:
Sat Apr 22, 2023 2:48 pm
Yes.
Do you have a reference ? I would like to check if the 25-27mm tire on 23mm iw wheels is still withhold. I don't have any intention to be a test object and don't want to risk going down due to some mismatch.
That said I run hooked rims 23mm inner and use pirelli 26mm on them. 25mm gp are smaller I found out and did t want to use them. The Pirelli's p zero clinchers fit as for example a Ere research 28mm at the same width and height
warthog101
by warthog101
I'd like to see it too. The link I posted is saying 2022. 28mm tyre on a 25mm int tss rim is ok according to it. The old P-Zero race certainly works on those sizes I posted here.
warthog101
by warthog101
Apparently there is a new one. I'm not paying 175 Euro though.
https://www.etrto.org/Publications/Orde ... RDS-MANUAL
parajba
by parajba
With an internal width of 21 (CLX50 from 2019), how wide is the 26mm version, inflated for a 67kg rider? I need to replace my GP5000 TR (non S) 25mm, with a high performance race tyre, with tan walls, and have pretty much narrowed it down to this model. Wanted to go 28mm but it's for an alpine grand fondo and I am worried about weight.
Opinions?
gorkypl
by gorkypl
parajba wrote:
Fri Apr 28, 2023 11:34 am
26mm should be specified for 18-19mm rim. On 21mm I would expect 27mm WAM.
Fuji Cross 1.5 - Shimano 105 5800 | Cinelli Superstar Disc - Record 12s | Custom steel Karamba - Ekar 13s
ipenguinking
by ipenguinking
Both front and rear show crack/seperation all the way around, on both sides. Tires are little over one-year-old, 1500 miles. Somehow they look more like seperation of 'tape' than crack to me.
ImageIMG_3758 by ipenguinking, on Flickr
ImageIMG_3756 by ipenguinking, on Flickr
TLN
by TLN
How does P Zero Road stacks against P Zero Race and GP 5000 S TR?
His: Orbea Orca OMX
Ytse
by Ytse
PIrelli is recalling some of its 28mm TLR tyres. Details here: https://www.pirelli.com/tyres/en-ww/bik ... res-recall
2020 Scott Addict RC / 2021 Trek Emonda SLR / 2023 Specialized Tarmac SL8
Mr.Gib
by Mr.Gib
"...some products might not guarantee 100% retention of inflation pressure on some rims currently on the market."
Don't they mean the tire might blow off the rim for no reason and you could die?
JayDee81
by JayDee81
Mr.Gib wrote:
Thu Aug 31, 2023 4:34 pm
I read that as they would deflate faster than normal (not suddenly) on these rims which is understandable.
JayDee81
by JayDee81
Ytse wrote:
Thu Aug 31, 2023 4:21 pm
It's still the same recall that has been mentioned a month ago here isn't it?
Requiem84
by Requiem84
JayDee81 wrote:
Mon Sep 04, 2023 1:13 pm
Yes.
Pottermouse
by Pottermouse
JayDee81 wrote:
Mon Sep 04, 2023 1:12 pm
A couple riders around this way have suffered from the "catastrophic and sudden".... think that is the main risk
JayDee81
by JayDee81
Pottermouse wrote:
Mon Sep 04, 2023 3:17 pm
Oh it's a quote from the recall. I didn't realize that before. In that case I agree with you.
