I know, I considered this option too.cannondale7om wrote: ↑Thu Oct 20, 2022 1:47 amYou can get the latest Hyper SE wheels for 900usd after the 10% discount. They are basically the same as the old Hyper 38/50/65 wheels, with matt coating and steel bearings.Roadrocket wrote: ↑Tue Oct 18, 2022 6:18 pmAny chance to help me get them this discounted? I´m considering Hyper 50 or 65 last months but 1100usd is still pricey.eliasharder wrote: ↑Tue Oct 18, 2022 4:32 amHi all,
I'm a youth roadie, 16 years old from Victoria BC canada. I've dipped into road racing in the past couple years and as we veer into the winter season I'm already planning my gear for next season as I hope to take my road racing a step up and try out some hill climbs as well (I'm 120lbs with a new set of hoops. Currently I'm running WH-RS370's @1820g set up with 25mm gp5k's on my '19 teammachine slr02 two disc.
Looking for some advice as to what wheels I should opt for. At the moment I'm leaning towards 38 or 50 disc hyper's - I've got a buddy in the industry who can hook me up with a set for ~800usd all said and done, as opposed to 1200usd + fees. From the research I've done this seem like a fairly good option for someone like me. For some context I'll be competing in faster cat4/cat3 equivalent next season (mostly road races 30-80kms) and like I mentioned hopefully trying some hill climbs. I'd also prefer not to be swapping wheelsets back and forth so I'll prolly be doing all my training on these (3-6 rides per week, 40-80kms with 500-1200m of elevation). Given these factors I'm pretty confident the hyper's will be my best bet but I'm very open to suggestions of other wheels and/or personal experience with this wheelset. I'm willing to spend a little more but I'm still in high school and now 100% on my own financially for bike parts. rip.
Finally, if I settle on the hyper's I'm torn on whether to go 38mm or 50. The ~75g weight difference is pretty negligible for me so I'm mostly concerned about cross wind stability vs the aero advantage with the deeper hoops. Victoria is pretty hilly so I'd say I frequently descend at 70kmh but I dont get much faster than that. Any insight on how these wheels perform in cross winds would be greatly appreciated, especially being a light rider as I mentioned. Thanks!!
For 800usd I´d try them for sure.
Winspace Hyper
Forum rules
will check that, thanksRoadrocket wrote: ↑Thu Oct 20, 2022 5:16 amNot true, bike24 offers them under 1500 too. Dark label Shimano: https://www.bike24.com/p2322466.html?so ... ku=1123068snowdevlin wrote: ↑Wed Oct 19, 2022 2:57 pmfrom what I've seen, bike-discount is the only site with those kind of prices (but hasn't got dark label shimano), all those other big online retailers got prices around 2000.Roadrocket wrote: ↑Wed Oct 19, 2022 2:36 pmI can have Bora WTO 60 from local dealer for about 1250. I don´t think it´s such of a shocking price since they are usually being sold under 1500 online:snowdevlin wrote: ↑Tue Oct 18, 2022 10:33 pm
Where can you get those similar prices on wto?
A few years ago I bought the wto 60 for less then 1500, now I'd like to get the 33 and they cost over 2000€
https://www.bike-discount.de/en/campagn ... gJN0vD_BwE
WTO 33 for 2000€? I don´t know where are you looking, but you can order WTO 33 for under 1500€ right now:
https://www.bike-discount.de/en/campagn ... n-wheelset
WTO 33 are currently 100€ more, but if you watch the price, you can get them cheaper.
Also I remember CRC offered them well under 1500 few months ago.
Quick question:
Will a 60mm valve for tubes work at the new "2023 45" backwheel, which is 54mm deep?
Or do I need 80mm valves?
Thank you!
Thank you!
I've just tested this with 65mm valves. I'd say 60mm would be too short. The 65mm worked but getting the pump head on when the tyre was flat was a slight pain with only about 12mm of valve stem showing. I reckon with 60mm you'd have 10mm or less showing with a flat tube when pushing on the tyre, so you may get a pump on it depending on the specific pump head, but I couldn't be bothered messing about. Therefore I've put the 80mm back on.KalleWirsch wrote: ↑Sat Oct 29, 2022 5:03 pmWill a 60mm valve for tubes work at the new "2023 45" backwheel, which is 54mm deep?
Thank you!
Personally, the 80mm leaves too much valve showing for my preference, but it works and is easy to get the pump onto.
Winspace got some nice deals for black Friday.
2 pairs of old Hypers will cost 1800 USD only now. Would be perfect for 23mm & 25mm tire users. Could have both 38mm and 65mm wheelsets for different uses or just upgrade wheels together with a best friend.
https://www.winspace.cc/black-friday-2022/
Farsports 10% off
https://wheelsfar.com/
Light Bicycle even better 20% off
https://www.lightbicycle.com/newsletter ... -2022.html
LOL
LOL
It is 900 USD per set so it is 25% off.Jasonlelam wrote: ↑Tue Nov 22, 2022 9:11 amFarsports 10% off
LOL
WINSPACE BETTER lol
Also T1500 + HYPER SE + Zero = $1730 = 40% off. BOOM
Just received the new 2023 Hyper R45s and have a Q for others:
The wheels come tubeless ready, with tubeless rim tape already installed. If I want to run tubes, is there other standard rim tape underneath the tubeless tape? Or will I need to purchase that and install separately after removing the tubeless tape?
Hi,
Had my Hyper Wheels Disc 50mm bearings replaced and was told I was missing the rear Hub washer seal the one that apparently fits over the freehub.Think I may have lost it when I took of my cassette a few months back and may have not realised.Does anyone know what this looks like and where I can buy a new one from?
Any help appreciated
Thanks Nay
Thanks Nay
Has anyone tried the 2023 D33?
I'm looking for a low-profile wheelset. The new LightBicycle Falcon Pro series might be good but the wavy profile is not my cup of tea.
