Forum rules
Turrifik
by Turrifik on Wed Sep 07, 2022 11:11 pm
timmerrr wrote:Been riding Feder 35s with RD230 Hubs for about 5 months now. Front wheel bearings are completely shot. Probably 4000 miles and only 1 ride in the rain. They have play in them and the balls have disintegrated. Kinda disappointed, but not surpised. Probably cheap bearings with no external bearing covers.
Sorry to hear that. I probably have close to that mileage and they’re ok so far, but I have been wondering how long the bearings will last. I put a water repelling grease on the exposed side of the bearings just in case
Might buy a spare bearing set from Farsports, or upgrade to NTN bearings, which I’ve heard some people do.
tiz92
by tiz92 on Thu Sep 08, 2022 8:29 am
I have similar km on my rd230 hubs and bearings seem still fine although I think I will also replace them during the winter with some low friction NTN bearings. I use my set only for racing. Do you know if its difficult to remove bearings from the rd230 hub?
timmerrr
by timmerrr on Thu Sep 08, 2022 1:37 pm
Brought the the wheel to the LBS and they are indeed toast. Should be easy to remove the bearings. They ordered some stainless bearings and I will be putting some water repelling grease on the outside after I get the wheel back.
Turrifik
by Turrifik on Fri Sep 09, 2022 8:46 pm
timmerrr wrote:Brought the the wheel to the LBS and they are indeed toast. Should be easy to remove the bearings. They ordered some stainless bearings and I will be putting some water repelling grease on the outside after I get the wheel back.
Good luck. If you can, let us know which bearings they install and how the hold up.
tritiltheend
by tritiltheend on Thu Sep 15, 2022 2:51 am
Had my Carbon-ti rear hub fail today, one of the non-drive side hubs failed. This is on a Feder wheelset in service for 22 months but with no crashes or unusual stresses. I weigh 168 pounds.
Contacted Farsports and waiting for an answer.
Mr.Gib
by Mr.Gib on Thu Sep 15, 2022 4:35 am
Ccare to post a photo? Did the flange crack around a spoke head?
You'll probably do better contacting Carbon Ti.
velomane
by velomane on Thu Sep 15, 2022 5:53 pm
I received a set of Feder's a couple weeks ago with the DT Swiss 180 EXP hubs. Were the rotor lock rings supposed to be included? If not, are they a separate purchase when building a disc bike?
Aesch
by Aesch on Thu Sep 15, 2022 6:14 pm
velomane wrote: ↑Thu Sep 15, 2022 5:53 pm
Not included usually. Shimano includes them with the rotor, other companies usually don't.
velomane
by velomane on Thu Sep 15, 2022 8:04 pm
Aesch wrote: ↑Thu Sep 15, 2022 6:14 pm
Damn! So two little lock rings are keeping me from enjoying my new toy.
tiz92
by tiz92 on Sat Sep 17, 2022 6:31 am
timmerrr wrote: ↑Thu Sep 08, 2022 1:37 pm
Was your lbs able to replace them easily? Over the winter Im thinking of chagning my bearings for some quality NTN or SFK bearings for next race season.
timmerrr
by timmerrr on Mon Sep 19, 2022 2:40 am
tiz92 wrote: ↑Sat Sep 17, 2022 6:31 am
Yup, with no bearing caps or anything, it's pretty easy to push out the 2 bearings and replace. Probably a 20 minute job at worst
uilewuit
by uilewuit on Sun Sep 25, 2022 10:23 am
not sure if this question has already been asked:
when comparing all of the offerings Farsports has, why would you buy anything but the gravel wheels?
if you put price and specs side by side, the gravel wheels come out lighter, wider, deeper and cheaper than any of the road offerings.
Is there something obvious I am missing here?
attached a comparison I made with a dt240 hub
