Light Bicycle wheel rims?
Forum rules
- MrCurrieinahurry
- Moderator
Looking fast!!!
Basso Diamante eps 12
I am also considering AR25 sincerely, but is 90Kg max limit bit scary? and could you tell me how long did it take to be shipped to your place?
I'm about 75kg...close but not super close to the limit. It doesn't concern me too much. Most of these limits are probably conservative anyways. I also don't ride gravel like a madman. The wheels took just under 2 months to be built and shipped to my place.
Thanks for your answer. I am going to make an order tonight. I chose 280g (slightly fortified version) for I am 80kgf and treat my bike like a boar. They say it will take 3~4weeks but I think I have to prepare for longer lead time according to your statement. Thanks anyway.
Keep in mind I ordered during the Black Friday promo which probably contributed to a surge in orders and longer lead times. I also chose the slowest/cheapest shipping option (by sea) since I wasn't in any hurry.Pyotrump wrote: ↑Sun Jan 29, 2023 5:56 amThanks for your answer. I am going to make an order tonight. I chose 280g (slightly fortified version) for I am 80kgf and treat my bike like a boar. They say it will take 3~4weeks but I think I have to prepare for longer lead time according to your statement. Thanks anyway.
Re: AR25, I'm interested in hearing about people's experiences with lateral stiffness. I'm currently running a 45m deep wheelset that I find a little jarring at times, so wondering if the AR25 would make for a more comfortable ride without sacrificing (too much) stiffness. For context, I moved to the 45mm wheels from a 25mm aluminium wheelset and prefer the much sharper handling of the deeper wheels.
Any suggestions how to remedy this? Perhaps LB can rebuild or let me upgrade?mpulsiv wrote: ↑Tue Jan 24, 2023 7:15 amI'm surprised that my AR375 Falcon Pro are rubbing on the chainstay (non-drive side).
www.lightbicycle.com/AR375-Non-Disc-X-F ... -700C.html
A combination of CX-Sprint spokes on drive side and wide flange on Bitex RAR9 is a solid combo. Any pointers as to why the wheel is rubbing? The flex is ~3mm when I'm climbing out of saddle. Is there a guarantee that AR465 will reduce flex since it's deeper?
1) Re-lace the wheel with CX-Sprint spokes all-around (drive side + non-drive side) = extra stiffness
2) Replace flyweight rim with standard = extra stiffness?
According to their blog, flyweight is stiffer due to mix of Toray T700 (standard) + Toray T800 (flyweight) layers https://www.lightbicycle.com/newsletter ... -Rims.html
3) Upgrade to deeper AR465 rim = extra stiffness
CBA = Chronic Bike Addiction
OCD = Obsessive Cycling Disorder
Your wheels are probably not lacking stiffness, quite the opposite actually. You might want to read that: https://www.slowtwitch.com/Tech/Debunki ... _3449.htmlmpulsiv wrote: ↑Mon Jan 30, 2023 6:43 pmAny suggestions how to remedy this? Perhaps LB can rebuild or let me upgrade?mpulsiv wrote: ↑Tue Jan 24, 2023 7:15 amI'm surprised that my AR375 Falcon Pro are rubbing on the chainstay (non-drive side).
I'd say it's actually your frame's chainstays that aren't stiff enough for the wheel.
Other option could be that the spokes aren't stiff enough for the rim given the thin margin between the frame and the wheel. Solution could be to go for stiffer spokes but definitely not stiffer rim.
Have you ever ridden wheels that wide on this bike before?
Can I ask what width gp5000s tr you fitted and do they line up fairly flush with the sides of the rim?
I've got a set of AR55 on the way and I'd like to run the new conti's in 28mm but just want to make sure they don't balloon wider than the rim.
I have a set of AR55 with 25mm GP5000 that measure 27.5mm and are pretty much flush with the rim as it tapers back in from the widest 30mm point to 28mm at the edge of the rim.
I replaced my QR skewers with Ultegra internal-cam ones and solved the rubbing issue. I have AR46 rims on Bitex hubs.mpulsiv wrote: ↑Mon Jan 30, 2023 6:43 pmAny suggestions how to remedy this? Perhaps LB can rebuild or let me upgrade?mpulsiv wrote: ↑Tue Jan 24, 2023 7:15 amI'm surprised that my AR375 Falcon Pro are rubbing on the chainstay (non-drive side).
Any news on this? Did you try the UFO with a tubeless tire?mrlobber wrote: ↑Thu Jan 19, 2023 10:30 amWhat they're still saying, I should try a tubeless tyre pumped up to max pressure, like 120+ psi, to be really sure the tyre has seated on the bed properly.
I haven't done that yet, but will do, even though, again, I have no idea how that would eventually correct this terrible wobble.
They said they use Giant tubeless tyre for QC testing (no idea why, no one would run them on a disc for a TT ), and the disc was fine with it.
