Well that's a very strong endorsement given your background. How is the X-Flow in cross winds? My WR50 are surprisingly good. I need another set of wheels which will see use in high mountains where anything can happen. Was considering the WR38. Sounds like the X-Flow might be the rim if it's stable enough. (Must admit I struggle with the wavy appearance. Hate "gimmicky" looking gear.)wheelbuilder wrote: ↑Thu Jul 11, 2024 7:54 pmIf anecdote counts, I have built a lot of LB rims and the Falcon Pro X Flow stuff is to my eye and inspection a higher quality finished product. Outer surface, spoke holes, and bed/hooks. So much so I bought two pairs for personal use. Aero wise I have no idea.
Light Bicycle wheel rims?
Forum rules
I’ve ridden them in strong cross winds with 32mm tyres, and while there is solid side pressure, it was not unmanageable. But I haven’t ridden in alps where there could be gusts as you twist around bends on high speed descents, or ride across peaks with extreme crosswinds.Mr.Gib wrote:My WR50 are surprisingly good. I need another set of wheels which will see use in high mountains where anything can happen. Was considering the WR38.
Do you find the WR50 too deep in the high mountains?
It seems a new X-Flow will be launched soon? Turbo?Its look just seems more strength against gusts but no idea about aero effect. https://www.lightbicycle.com/newsletter ... etter.htmlMr.Gib wrote: ↑Sat Jul 13, 2024 12:08 pmWell that's a very strong endorsement given your background. How is the X-Flow in cross winds? My WR50 are surprisingly good. I need another set of wheels which will see use in high mountains where anything can happen. Was considering the WR38. Sounds like the X-Flow might be the rim if it's stable enough. (Must admit I struggle with the wavy appearance. Hate "gimmicky" looking gear.)wheelbuilder wrote: ↑Thu Jul 11, 2024 7:54 pmIf anecdote counts, I have built a lot of LB rims and the Falcon Pro X Flow stuff is to my eye and inspection a higher quality finished product. Outer surface, spoke holes, and bed/hooks. So much so I bought two pairs for personal use. Aero wise I have no idea.
Wouldn't even consider taking 50mm wheels on a mountain trip - I have always have used shallow allow wheels. Deeper wheels might be fine most of the time, but I've been in too many situations where anything deep would have been very bad. I have seen people walking because of the wrong wheel/wind combo. I have had my WR50 in 35 - 40km/h winds and they were very good, but that's in manageable terrain near home. Descending a big pass in a thunderstorm with powerful gusts can be borderline with the shallowest wheels.emotive wrote: ↑Sat Jul 13, 2024 12:30 pmI’ve ridden them in strong cross winds with 32mm tyres, and while there is solid side pressure, it was not unmanageable. But I haven’t ridden in alps where there could be gusts as you twist around bends on high speed descents, or ride across peaks with extreme crosswinds.Mr.Gib wrote:My WR50 are surprisingly good. I need another set of wheels which will see use in high mountains where anything can happen. Was considering the WR38.
That's even stranger looking - I'm out. Major Kudos to Light Bicycle for pushing the envelope though. Very happy to give them my business.Jasonlelam wrote: ↑Mon Jul 15, 2024 3:59 amIt seems a new X-Flow will be launched soon? Turbo?Its look just seems more strength against gusts but no idea about aero effect. https://www.lightbicycle.com/newsletter ... etter.html
I have no idea if this kind of sharp fin is useful or not, but if it could help flow separation, the direction should be opposite.
I will certainly buy this rim if the width meets my requirements and the general cross section is not off, purely for its aesthetics.
The conti Aero 111 might be interesting for someone like you to try to help mittigate crosswind impacts on handling. If you do please post your experience given it seems like you actually push your equipment and give real feedbackMr.Gib wrote: ↑Mon Jul 15, 2024 3:51 pmI’ve ridden them in strong cross winds with 32mm tyres, and while there is solid side pressure, it was not unmanageable. But I haven’t ridden in alps where there could be gusts as you twist around bends on high speed descents, or ride across peaks with extreme crosswinds.
Hi, I'm looking for WAM tyre measurements for GP 5K S TR. Do you run these tyres? Looking at either a 28mm or 30mm, want to stay within the 105 rule.sirRob wrote: ↑Tue Aug 17, 2021 11:30 amI am still very satisfied with them. I use them only in the mountains at the weekend and they perform just as good as the Bora Wtos did which they replacedpmprego wrote: ↑Tue Aug 17, 2021 9:52 amAny feedback by now?sirRob wrote: ↑Sat Jul 17, 2021 10:47 pmI am using ar375 lightweight option with carbon ti hubs.pmprego wrote: ↑Sat Jul 17, 2021 10:14 pm
I understand that. Yet... If Zipp says "this is inspired in Wales" people will say "awesome" but if a Chinese company says what they said it is not believable. Just as specialized saying it's x amount of seconds faster. Or any other brand saying that their wheels are faster than the competition. All of those are claims that cannot be really verified.
But one does however he/she/they wants.
In my case, I try to get averages. If people with the X-flow 375 or 465 can confirm inner width, hook width and maximum width I'll be more than fine. On top of that which tires are using and their real measured width than it's just perfect.
The same goes for the wr40.
Inner width: 21,8mm
Hook width: 28,9mm
Maximum width: 30,3mm
Pirelli pzero Race 28C (tubetype) come in at 28,7mm@5,3bar
Very satisfied how they handle in crosswinds!
Thanks for any help, no dramas if you don't have this info.
Kurt
Ridley Helium SLX - RIP https://weightweenies.starbike.com/for ... lit=ridley
Scott Foil - current viewtopic.php?f=10&t=173046&p=1813155#p1813155
Damn, those hubs tho! 210 g for a set of non-side entry carbon spoke hubs.
24 mm internal 32 ext rims. Sub 1200 g for 50 mm wheel.
Sounds amazing on paper. The rim profile and LB's carbon spokes are the only questionmark for me
Boy do these new rims look da bomb.
This.
I'm with Mr.Gib on this one after this year's Marmotte, where descending from the Galibier in those winds was something I'd rather not experience again (I was on 50mm Farsport Hypers there).Mr.Gib wrote: ↑Mon Jul 15, 2024 3:51 pmWouldn't even consider taking 50mm wheels on a mountain trip - I have always have used shallow allow wheels. Deeper wheels might be fine most of the time, but I've been in too many situations where anything deep would have been very bad. I have seen people walking because of the wrong wheel/wind combo. I have had my WR50 in 35 - 40km/h winds and they were very good, but that's in manageable terrain near home. Descending a big pass in a thunderstorm with powerful gusts can be borderline with the shallowest wheels.
Interesting idea, but I, for instance, would always prioritize grip (and wet grip! where Contis never really shine) over aero or even RR in the mountains.OtterSpace wrote: ↑Tue Jul 16, 2024 9:07 pmThe conti Aero 111 might be interesting for someone like you to try to help mittigate crosswind impacts on handling.
At this stage I'd not recommend any wheel with carbon spokes plus generic/ODM hubs. My friend got AR565 with the latest gen LB carbon spokes and hubs. Not great at workmanship (bearing binding, echoed by Hamb1n1) and hub geometries may contribute to the draggy feel when climbing.toxin wrote: ↑Wed Jul 17, 2024 10:41 amDamn, those hubs tho! 210 g for a set of non-side entry carbon spoke hubs.
I wish one day LB will become a true wheel manufacturer with in-house designed hubs and rims. That way they can create something truly awesome.
