Light Bicycle wheel rims?
Forum rules
@Schoenrock I'll do that once they arrive. My invoice shows "steel bearings" but I didn't have the option to change that out when I purchased them since they were the preconfigured wheel set. Here's some photos that LB sent me:
looking really clean! congrats again and fingers crossed they arrive soontonytourist wrote: ↑Mon Dec 02, 2024 11:43 pm@Schoenrock I'll do that once they arrive. My invoice shows "steel bearings" but I didn't have the option to change that out when I purchased them since they were the preconfigured wheel set. Here's some photos that LB sent me:
Ordered a set of AR56 disc in carbon spoke configuration using their speed hub gen2 during BF sale - will probably take a while for build/shipping. Couldn't find too many posts on their new carbon spokes and gen 2 hub but they seem to be ok (some reports of play in bearings). Does anyone have recent experience or issues to be aware of with hubs/spokes for their carbon spoke builds?
What would you say is more durable for off-road riding (with a 50mm tire): a WR40 x-flow standard weight or a AR25 with extra carbon reinforcement for more off-road durability. And why?
And a separate question: The XC924 has a hybrid hook and an inner width of 24mm and acc. to LB works with 2.1-2.4" tires. The WR40 has a standard hook and a 25mm inner width. Given these hook and inner width specifications shouldn't the WR40 also work with 2.1 to 2.4 inch tires?
I recently used DT Swiss XMC1200 rims built up onto DT road hubs for a gravel wheelset for some 50mm tyres. I thought the 30i would be good for 50mm tyres. I found the ride more harsh, so switched the tyres onto 29i gravel wheels and they are more comfortable. This is a small sample size but the XC rim is built to a MTB specification while the gravel rims are potentially not.goroldM wrote:What would you say is more durable for off-road riding (with a 50mm tire): a WR40 x-flow standard weight or a AR25 with extra carbon reinforcement for more off-road durability. And why?
I would expect the MTB rim would be more durable off road because it is designed to sustain for bigger hits.
Yes, the WR40 will work with 2.4” tyres also. It’s just at that size (and resulting low tyre pressure) you don’t really need a hooked bead. And you potentially want a MTB wheel rated for hitting big rocks. But it will work.
The AR25 and XC 924 are variants of the same rim; LB announced them simultaneously. Presumably there are differences in the layup to withstand more pressure or more width respectively.
A while back I asked LB about running wider (55-57mm) tyres on one of their i25 gravel rims (recommended for 28-50mm) and they said it'd be fine. FWIW, ETRTO says i25 is okay for 29-71mm, but rim manufacturers' specs vary.
Light bicycle categorizes both of them as gravel rimsemotive wrote: ↑Sun Dec 08, 2024 10:00 pmI would expect the MTB rim would be more durable off road because it is designed to sustain for bigger hits.goroldM wrote:What would you say is more durable for off-road riding (with a 50mm tire): a WR40 x-flow standard weight or a AR25 with extra carbon reinforcement for more off-road durability. And why?
Which model of LightBicycle wheels, are now considered as top road model? With lightest rim, carbon spokes, and wider internal rim. So optimal acceleration and stifness.
Comparable with Farsports S EVO and Hypers with carbon spokes on wheelsfar.
I don't think carbon spokes should be considered "top" as it limits the choice of hubs, and the so-called latest revised speedhubs that the carbon spokes needed are unproven yet.
Nevertheless for me carbon spokes are the best (specially for my riding style), and now already have severasl wheels with them. And I am not going back to steel spokes.
Ordered a set of WR45s recently for my Tarmac SL7. Hooked and plan to run tubes. Are people going with 28mm or 30mm tires?(I know ETRTO doesn't support 28mm on 25mm ID rims but I think that is mainly applicable to hookless?). Will be using Conti GP5000s. I weigh 148lbs and ride typical Socal roads. Maybe 28mm front and 30mm back for best aero/comfort combo?
I've been running Conti GP5000 in STR and TT-TR on WR series rims (WR50 and WR65) for 2 1/2 years, at 28 mm size, all tubeless. When mounted they are 31.8 mm WAM, and after some time they measure at 32.6 mm. That violates the 105% rule, but that rule is an observational guideline and I find the wider used tires don't seem to notably add drag or change the wheel's very nice, benign cross wind characteristic. But, being an aeroweenie, I'd be hesitant to add another 2 mm with the 30 mm tire, without someone else chiming in with good experiences going that far away from 105%
You won't have problems with 28 Conti. 30 rear tire works fine also. That's my combo on WR50s.Duylamphan wrote: ↑Fri Dec 13, 2024 5:26 pmOrdered a set of WR45s recently for my Tarmac SL7. Hooked and plan to run tubes. Are people going with 28mm or 30mm tires?(I know ETRTO doesn't support 28mm on 25mm ID rims but I think that is mainly applicable to hookless?). Will be using Conti GP5000s. I weigh 148lbs and ride typical Socal roads. Maybe 28mm front and 30mm back for best aero/comfort combo?
I'd urge you to consider tubeless. If you are avoiding tubeless because it is just something you haven't done, don't fear the learning curve - invest in an Airshot and jump in. The LB rims were very easy to set up with GP5000S TR. I still use inner tubes for travel and bikes that might spend months without being touched, but tubeless for everything else.
