Forum rules
garbageman
by garbageman on Fri May 19, 2023 9:26 pm
mpulsiv wrote: ↑Fri May 19, 2023 7:33 pm
oLLeg wrote: ↑Fri May 19, 2023 11:14 am
Erwin wrote: ↑Wed Apr 12, 2023 7:21 am
@mrlobber: Finally, I wish you a good ride and hope you are happy with it (now)!
@all: Someone rides the AR25 with 28mm tires? I think GP5000 S TR 28mm will be about 30,5mm on a 24mm inner rim. I want a AR25 wheelset for my O2 for climbing in the alps. Is is stiff enough with CX-Ray/CX-Sprint or should I choose 48x CX-Sprint (or perhaps carbon spokes, which I don't prefer)? My weight is about 68kg +/- 1kg. Thanks for your thoughts!
I'm thinking about same wheelset. I need light wheelset for climbing , not for gravel. No carbon spokes. I'm concerned about hybrid hooks AR25 have. TRhey say, I will need very low pressure in tyres (<70 PSI). It means only tubeless? Will it be safe/good to ride down on such low pressure?
70 psi is not low presure, unless you ridding 23mm tires from 2012 era.
Low pressure is considered ~50 psi.
Refer to
viewtopic.php?f=3&t=172702&sid=c4f1a0b6 ... de6399b9a8
70 psi IS low as a max pressure. I'm only 55kg but I used over 70 psi in 30mm WAM tires (GP5K S TR 700x28c) in 2 races on smooth pavement recently (as recommended by the Silca pro calculator). The AR25 was clearly developed as a gravel rim. As appealing as it is as a superlight road rim, the max pressure limitation means you need to run larger (heavier) tires or accept slightly compromised rolling performance on good roads. That said, the "penalty" for running lower than optimal pressure is very small and even heavier riders would be fine ("safe/good") using <70 psi in tubeless tires on AR25s.
I would treat the hybrid hook design as hookless wrt tire selection - i.e. I wouldn't use non-tubeless ready clinchers.
Jasonlelam
by Jasonlelam on Sat May 20, 2023 2:17 am
MrRolandos wrote: ↑Fri May 19, 2023 5:15 pm
I got a set of LB AR55 PRO, anyone has any experience with LB mountainbike wheels? Willing to give that a go when a sale pops up.
Mountain is not my territory at this stage and those Light Bicycle stuff Looks super burly and great especially the last one's 'weavy' profile that the nipple holes placement are alternatively at the top/bottom area on the rim, interesting.
https://www.youtube.com/watch?v=NAfeg5ueRcY
MrRolandos
by MrRolandos on Sat May 20, 2023 5:00 pm
Jasonlelam wrote: ↑Sat May 20, 2023 2:17 am
Looks like a great review. Never got my wheels made by LB themselves but this looks really good. Those AM930S look very interesting with the weavy profile and 30 internal. They are a bit on the heavy side.
oLLeg
by oLLeg on Sun May 21, 2023 7:48 pm
garbageman wrote: ↑Fri May 19, 2023 9:26 pm
Thanks for the best explanation I ever found. While I'm absolitely happy withAR45, no crosswind affect, still straight and fast wheel just about 1400 gr, I'm thinkung to try very light wheels. But not ready to start with tubeless yet.
Which tyres wouyld you advice, non-tubeless fior AR25 then?
garbageman
by garbageman on Sun May 21, 2023 8:53 pm
oLLeg wrote: ↑Sun May 21, 2023 7:48 pm
TobinHatesYou wrote: ↑Sat May 20, 2023 12:47 am
FWIW, Light Bicycle does claim the hybrid hook is regular clincher compatible
I made an assumption about the hybrid hook that is incorrect (according to LB). I'd still be a little bit hesistant about running regular clinchers near the rim's max pressure and I wouldnt run a 25c/26c tire, but a 28-30 should be fine (although a 28 would be just outside of the 2023 ETRTO guideline). Alternatively, you could run a tubeless-ready tire with tubes for some extra peace of mind, but it's a bit counter-productive to the idea of a superlight wheelset (maybe not if you use light TPU tubes).
Schadenfreude
by Schadenfreude on Tue May 23, 2023 6:56 am
I just wanted to add that I have a set of AR46 without spoke access holes and have had no issues setting up tubeless without tape. I'm fairly new to tubeless and I was able to set up a set of Pirelli P Zero TLR with a standard floor pump and Orange (regular) sealant. After 6 months I removed them, cleaned out the existing sealant and setup them up again with the same floor pump - absolutely no issues.
Hexsense
by Hexsense on Tue May 23, 2023 4:32 pm
MrRolandos wrote: ↑Sat May 20, 2023 5:00 pm
Too heavy.
Light-bicycle seems misguided that light XC need to be narrow (24mm internal width).
And anything 30mm internal width must be built burly to withstand severe abuse.
Eie make light and not narrow XC rims. 30mm internal in UL (ultra light) version weight 285g per rim versus 350-400g Light-bicycle 30mm internal.
https://www.eiecarbon.com/goods/details/A29C30D20
For mtb, Rim weight is not just rolling weight. It's unsprung weight.
gshb
by gshb on Tue May 23, 2023 4:57 pm
garbageman wrote: ↑Sun May 21, 2023 8:53 pm
Just to add, many people including myself have asked LB to add additional carbon layup (reinforce) to AR25, anywhere between 15-30g per rim for higher max pressure 80psi.
Pyotrump
by Pyotrump on Tue May 23, 2023 4:59 pm
gshb wrote: ↑Tue May 23, 2023 4:57 pm
Haha I was not the only one! I did not know that it also increases max P. I addded 30g each so 60g in total.
MrRolandos
by MrRolandos on Tue May 23, 2023 7:33 pm
Hexsense wrote: ↑Tue May 23, 2023 4:32 pm
Too heavy.
Interesting, I find that everyone says 30mm seems to be the more modern internal width. You see the same with road rims, all 21C now. Im more heavy (86-87kg at 196cm) and 30mm would be better support I guess? I will look at those rims you linked!
gwilson
by gwilson on Wed May 24, 2023 2:20 pm
Has anyone ever shipped their own hubs to Light Bicycle and had them build up a wheelset for you? I have a pair of cracked rims with DT Swiss 240 hubs where I want to keep the hubs, so would rather just buy new rims/spokes and get the built up with my existing hubs
