Making the transition to tubulars
Forum rules
I am about to do my first ever transition to Tubulars, but don't want to look like an idiot ungluing/gluing tubulars on a side of the road in case of a puncture.
Is Conti Sprinter Gatorskin sounds like a good solution to you?
Also, if I use tape will changing tubulars become easier?
2018 Cannondale SuperSix EVO 2 rim size 56 (raw stripped) 6.8kg
2014 Bridgestone Anchor CX6 Equipe size 55 (cyclocross) 9.6kg
With tape it is a lot easier.
I have used Gatorskin; it is a very harsh tubular. In wouldn't recommend it. My experience with dealing latex tubulars has been very good. Also, 25 mm require a bit less pressure than 23mm, sealing better.
Any new tubular tires incoming 2022 TdF?
nvm, couldn't wait any longer and got Challenge Strada Ultra 27mm. Lovely tires!
Finally decided to make transition to tubulars, and pulled a trigger on used 2017 Zipp 202 tubulars (latest generation), in great condition for little above 400usd.
About tires, what could you say about Conti Force Comp tubulars front and rear?
That is what glued at the moment.
Here is my first tubular setup.
Got theese 2016-2018 era Zipp 202s with Zipp skewers, valve extenders and Conti Force Comp tires with plenty of life left, glued in for 400usd. Cleaned, serviced freehub and it came out a one gorgeous wheelset I might say! No scratches, very little lateral runout, bearings are smooth, even stickers are looking almost mint! Will run these with Zipp Platinum brake pads.
Now the question is: what sealant to use for this butyl inner tubes?
I trust Orange Seal. It works on my Corsa Control with latex tube. Other people also have positive exp with it.charirider wrote: ↑Wed Jul 27, 2022 1:08 amHere is my first tubular setup.
viewtopic.php?f=3&t=135991&p=1708718#p1708718
Thank you! Will order this.jlok wrote: ↑Wed Jul 27, 2022 1:42 amI trust Orange Seal. It works on my Corsa Control with latex tube. Other people also have positive exp with it.charirider wrote: ↑Wed Jul 27, 2022 1:08 amHere is my first tubular setup.
It seems impossible to find Orange sealant here in Japan, but I can easily get Stan's NoTubes in small 50ml bottle. Is it ok for butyl inner tubulars? In particular I have Continental Force Comp tires.
Should be fine. If you could find it - I ve had good experience on tubulars with Bontrager's sealant.charirider wrote: ↑Sat Aug 13, 2022 9:56 amIt seems impossible to fing Orange sealant here in Japan, but I can easily get Stan's NoTibes in small 50ml bottle. Is it ok for butyl inner tubulars? In particular I have Continental Force Comp tires.
Corsa Controls are good. On normal roads (with some grit), I am fine with standard Corsa.
Some other options in 27-30mm. Bike24 filters shows quite a few models. Veloflex is expensive; Challenge has good offers - but I have had them fail in the past and the ones with latex inner tubes get more pricey.
