The CAAD Build Thread...
SixThirteen
by SixThirteen
Don't post very often, but I do like my CAAD9
Full DA7900 except the chainset
About 7.4kg with the commuter / hubbardry / fred gear
About 7.0kg clean.
eggleston
by eggleston
Frame: 2012 CAAD10 54cm
Wheelset: 2009 Campagnolo Eurus
Handlebar: Bontrager XXX Intergrated
Crankset: 2009 Campagnolo Chorus
Seat Post: Deda Superleggero
Saddle: Fizik Volta R1
Pedals: Speedplay Stainless
Shifters: Sram Force 10s
Front Derailer: Sram Red 10s
Rear Derailer: Sram Rival 10s
Brakes: Sram Rival 10s
Cassette: Sram Red 10s
Chainring: Sram 10s
Tires: Veloflex Corsa 23c
Finished in 6.9kg, custom painting for frame, Handlebar and seatpost.
rukomasa
by rukomasa
Hi, I am a new CAAD user, just got CAAD12/2016/54cm. Just wondering if anybody has the same issue i have.
I am using shimano 5800 105 11spd and cant get satisfied with B tension properly.
If i make it strong enough to not rubbing chain with small/small cogs, shifting is not so good at outter ring+lower three rears. if i set to weak enough for large front, pully rubbs at lowest gear with small front.
I assume the reason is the RD cable housing. does anybody have a bright idea?
i was running 11/28+50/34
Tapatalk を使用して私の SOL26 から送信
garjo
by garjo
rukomasa wrote:Hi, I am a new CAAD user, just got CAAD12/2016/54cm. Just wondering if anybody has the same issue i have.
in my opinion it appears to have a too short RD cable, compare it with that red caad12 posted above in this page
My 4,93 kg Supersix Evo HM: viewtopic.php?f=10&t=137647&start=30
My 6,22 kg Cannondale R500 1996: viewtopic.php?f=10&t=134364
rukomasa
by rukomasa
Thank you garjo! I just tried an inch longer. Much better now.
angryfrank
by angryfrank
proud owner of CAAD12 Dura-ace Disc 2016.
I have one question I have been searching high and low for a carbon 0 set back seatpost (25.4mm) and cannot find anyone that makes one, does anyone know of a one off hand?
cheers
Peeza21
by Peeza21
angryfrank wrote:proud owner of CAAD12 Dura-ace Disc 2016.
cheers
http://www.ebay.co.uk/itm/Hylix-Carbon- ... CzZl6RzJlg
Super light and work well, I have one on my caad12
Cannondale Supersix Evo HiMod 2012 viewtopic.php?f=10&t=148290
Cannondale Caad12 2017 viewtopic.php?f=10&t=143217&p=1389852#p1389852
Hazzles
by Hazzles
Trying out some Vittoria Corsa G+ tyres at the moment, impressed so far.
prebsy
by prebsy
Drilled my old caad10 frame for di2, still need to get the cockpit cleaned upImage
Sent from my SM-G925T using Tapatalk
gtinut
by gtinut
do you have close up pictures of the holes?
prebsy
by prebsy
They are plugged up now but they are 1/4 inch and mimic the location from the old black inc di2 frame. It was shockingly straightforward.
proudCAAD12
by proudCAAD12
cheers
I just picked up a Cannondale C2 25.4mm (350mm) 15 mm offset that is about 54 grams lighter than the stock C3 alloy seat post. The new seat post has plenty of room to chop off so I'm hoping to save another 80 grams or so. I paid $79.99 from Bicyclebuys.com
The new c2 post weighed 249.48 grams on my scale and the old C3 weighed 303.34
I do have a question though. The stem doesn't look carbon, but the packaging says it is. Does it just not look like "typical" carbon because it's Unidirectional carbon? I'd like to know for sure before I send it back or keep it and chop it.
Here is a link to a FSA zero offset 25.4mm http://www.outsideoutfitters.com/p-4389 ... oCEjrw_wcB that claims weight at 197 g for 350mm
Thanks in advance!
2017 Cannondale CAAD12
2005 Trek 7.4
Oldie Dahon Boardwalk
r33prman
by r33prman
Posted in the cannondale thread but needs to be here too.
Caad12 58cm
Zipp 404 vittoria corsa 25c
Sram red 22 with bespoke chainrings
Deda zero100 bars and stem
Cannondale c2 carbon post
Pro stealth saddle
Carbonworks bidon cages.
Comes in at 7.12kgs.
Needs a lighter seatpost I reckon. Recommendations?
jinnie799
by jinnie799
is this 2017 caad12? if so, this frame use 25.4mm seatpost. I recommend MCFK, ENVE, or Cannondale speed save seatpost.
