The CAAD Build Thread...
Moderators: maxim809, Moderator Team
Leon
by Leon
Yes, I saw that in your post. But I don't run cables through the downtube. The shifters on the 8170 are wireless (luckely!).
Ride bikes, not tanks!
Ricenpeace
by Ricenpeace
cmunozh wrote:Hi all,
Here is another caad12 user from Zürich ( :-) ). I had a "small" accident with my former caad12 and I am looking for some vertical tube ring or adaptor where I could place my front derailleur. Do you know if that type exists? The vertical tube at that section is not circular :-(
cheers,
Cmunozh
Hi. I have another CAAD12 Frameset in 58 here in Zurich if you fancy it.
cmunozh
by cmunozh
Ricenpeace wrote:
Sat Dec 30, 2023 10:16 pm
cheers,
Cmunozh
Thx a lot but a 58 would be like a horse to me, being 170cm :-P . I use either 48 or 50.
Happy new 2024
Cheers,
Carlos
My garage: Caad12, BRT C0, Cannondale Scalpel SE II, Specialized Epic pro '92, Swiss military bike '45, Orbea Gredos '87, Specialized Langster '12, Caadx '15...
AM7Jeremy
by AM7Jeremy
I am 178cm and typically ride 54cm frames but the CAAD12 runs a size big in my expierence. I curently ride a 52cm CAAD12 with a bit of more spacers to replicate my fit on my other 54cm bikes.
tarmackev
by tarmackev
Spessartpantani wrote:
Wed Jul 27, 2022 8:44 am
Caad9
54er SI
Hollowgram Crankset with power2max
Campagnolo Record/Chorus 11speed Mix
Campagnolo Bora One 50
Thomson Stem Seatpost
Deda Superzero
Tune Kom Vor
:D
I love this.
Singlish
by Singlish
AM7Jeremy wrote:
Fri Jan 05, 2024 5:16 pm
Are we talking about stack and reach? Compared to a Tarmac in 54 the CAAD is about 7mm higher and the reach close to the same. Oddly I ride an SL6 54 with 20mm spacers inc. headset cover and a 120 stem and a CAAD12 56 slammed with 110mm stem and they're pretty close in that configuration. Definitely should have bought the CAAD in 54 but I liked the colour and it was only left in that size.
AM7Jeremy
by AM7Jeremy
Have a soft spot for CAAD's. Quick project I wrapped up not too long ago.
52cm CAAD12
SuperSix EVO Hi-Mod fork (sanded down)
Enve 5.6
eeBrakes G4
Jagwire Elite Shifter/Brake cables
SISL2 crankset
Kalloy Uno Stem/Seatpost
Prime Alloy 38cm handlebars
aaronffs
by aaronffs
about it
hello
Singlish
by Singlish
AM7Jeremy wrote:
Fri Mar 01, 2024 2:32 am
52cm CAAD12
Enve 5.6
eeBrakes G4
SISL2 crankset
We've got the same frame colour, looks so glorious in bright daylight. What's the final weight?
AM7Jeremy
by AM7Jeremy
Singlish wrote:
Tue Mar 05, 2024 2:47 am
52cm CAAD12
Enve 5.6
eeBrakes G4
SISL2 crankset
7.2kg. Will be upgrading to a carbon seatpost and lighter saddle here shortly
KuB3
by KuB3
Hi there!
There is my 2001 CAAD5, 7.2kg without pedals so definitely not much in the weighty weenies...!
It's build with a mix of Sram Red, Rival and Force 10s, Vittoria Qurano wheelset, Argon18 carbon components and Ti bolt everywhere.
I recently updgrade to a 2nd Gen Red 10s groupset and replace the integrated handlebar with a Bontrager RSL AERO, but not proper pictures for the moment.
I'm not looking to shave some weight anymore, it run perfectly like that, and without swaping the frameset I don't think I could really shave some big grams
BalticSea
by BalticSea
Thinking about building up semi-lightweight alloy bike for all-weather conditions, just in case I don't want to get my carbon bike out.
How feasible would it be to build a Caad8 (mid 2010s, size 54) with alloy wheelset to get around 7.5kg with pedals and cages? I assume replacing the fork with one that has carbon steerer would be a decent start?
My other option would be getting a 2018+ rim brake Allez in the same size, althought the frame set would be bit heavier than Caad with full carbon fork, not to mention more expensive.
KuB3
by KuB3
You're right, start by the fork, you can shave nearly 300gr with a carbon steerer one.
With a light alloy wheelset, 7.5kg is easy to reach
My previous wheelset was an alloy and is lighter than my actual carbon one.
Find a nice crankset, carbon seatpost and an Uno stem and you'll be good!
peezy
by peezy
Will I regret selling this for an Allez Sprint Disc?
