Let's See Your Time Trial bike
dominikk
by dominikk
marcelflash wrote:
Mon Apr 15, 2019 2:58 pm
This is my Merida Time Warp.
Tririg Alpha X Bar, custom extentions.
tririg Omega X brakes
Dt-Swiss rearwheel old 10 speed with a 11 speed Rotor cassette
Dt-Swiss 80 mm frontwheel
55t front chainring
XTR 12 speed chain and pulleys
Viewspeed QR
Nice! Nice!
Where did you order TriRig stuff?
Online from USA or where in Europe?
Thanks.
Riding Paniagua - The Future of cycling!
reedplayer
by reedplayer
After almost 8 years on BMC TT02, i replaced it with a Basso Konos. Got the Frameset, incl. Bar, Brakes, and everything, really really cheap in new condition.
i like the geometry with the 75°-seat angle and the short headtube.
The first race will be on 28.04., looking forward to it and preparing it carefully!
Picture with 38mm-training wheelset.
The saddle-bb-offset is 5 cm.
Further it has Bepro Powermeter-pedals and a Dash stage 9.-saddle as "special features".
Weight is 7,92 kg
marcelflash
by marcelflash
dominikk wrote:
Wed Apr 17, 2019 9:49 am
55t front chainring
Viewspeed QR
Nice! Nice!
Thanks.
Yes from USA but had to pay customs and taxes I knew in advance but TriRig are relaxed about that.
I think TriRig is better quality than my outgoing Zipp Vuka Stealth.
Kristof047
by Kristof047
As I do not really ‘love’ TT training, but do participate a TT race or 3 a year. I build me something versatile instead of a full TT bike. Aero was only 2nd priority, but didn’t want to compromise on the body position.
TT setup weights 8.93 kilo’s including pedals and 3 bottle mounts. Some parts I specially chose for functionality over weight, aero, ...:
- Cinelli Vigorelli road frameset, because I wanted steel, brake cable external for easy removal. High bottom bracket for fixie races and has some streed credibility when used in fixie races 8)
- Haero Carbon H155 handlebar: normal clipp-ons are too high for my position + easy to remove extensions or add triathlon U-bar.
- 1x11 Etap for shifting at extensions and easy change for track/fixie mode.
- Redshift dual position seatpost for TT and Road position on the go.
- Fabric Cageless bottles, because most TT’s are short and don’t need bottles. I think just bolts are faster than empty cages.
- Fabric TT saddle for comfort
- Some cheap Chinese tubular wheels with Aerojacket for aero purposes.
- Other components are reuses from the spare bin.
Also have White Industries Eno Eccentric wheels, so with just minor work the bike can and will be used as TT-bike, Sprint triathlon bike, crit bike, fixie with brakes and track bike without brakes. Just requires wheels swap, chain swap, derailleur removement and for track, brake removal (actually I just swap the entire handlebar which is faster).
dominikk
by dominikk
@Kristof047
Interesting ... very interesting.
Juanmoretime
Administrator
by Juanmoretime
Kristof047 wrote:
Tue Apr 23, 2019 7:22 pm
Sort of old school beautiful. Well done!
RESIDENT GRUMPY OLD MAN.
Markcanyon
by Markcanyon
CrankAddictsRich
by CrankAddictsRich
Anyone out there using the Shimano SW-R9160 bar end switches? I'm currently using the two-button Ultegra 6870 TT buttons and I thought the SW-R9160 switches would minimize things at the end of my extensions... I just can't quite find any good information about how the wires connect. It appears as if the wire runs right up the middle, but then I can't figure out how they're tightened into the bar ends.
Jugi
by Jugi
I would adhere to the installation manual on this one (Shimano has quite good manuals after all), but based on how the shifters look, they have surfaces for either a 17mm or a 19mm flat cone wrench. Most likely there is a hollow allen bolt inside which will tighten that expander while the shifter's base is inside the extension bar. By holding the base in the preferred position with a cone wrench, you resist it twisting while tightening the expander.
So, dismantle the actual shifter from it's base. Route the wire through the extension and the shifter's base. Install the base. Connect the wire to the shifter and install the shifter to it's base. It may just snap into place or it may have a securing screw on the underside.
rainerhq
by rainerhq
I have these on my TT bike.
No need to dismantle anything. Hold the shifter in place and tighten with 23mm cone wrench or pliers etc.
Domane
Speed Concept
"Nothing compares to the simple pleasure of a bike ride"
CrankAddictsRich
by CrankAddictsRich
Jungels and Majka were on a new Shiv TT disc at the Giro.
I haven't been able to find good pictures of either, but from what I can peice together from images... it looks like a similar fork shape to the revised rim brake fork, but with disc brakes (obviously) the bar and cockpit is deifnitely revised and appears to be simpler/flatter than the previous Shiv TT. The support brace between the elbow pads is rather far apart on Jungels bike, much more so than would be capable on the rim brake bike. The underside of the top tube appears to angle into the rear of the headtube, while the older model curved. The seat stays also appear to have been dropped quite a bit, simialr to the newer, non-UCI model.
here's a zoomed in and brightened crop.
CrankAddictsRich
by CrankAddictsRich
Custom bars for Roglic, Campenaerts and Nibali in the second TT at the Giro.
Maybe custom bars for Yates, as well?
Shiv TT Disc for Jungels and Majka in the second TT.
Canch
by Canch
My BMC:
2019 BMC TM02 Frameset
Campagnolo Chorus 11sp Groupset
Tririg Omega X brakes
Vision Metron TFA handlebar
VENN VAR77 with DT240s Wheelset
Corsa Speed tubeless tires
Prologo seatpost
Ceramicspeed OSPW and chain
Calnago
by Calnago
CrankAddictsRich wrote:
Great shot of Nibali. He looks almost “comfortable”. Almost Image
Konsi
by Konsi
Not really Time Trial, more triathlon, but I think it might fit here as well :)
