Let's See Your Time Trial bike
Tinea Pedis
by Tinea Pedis
Reply from the UCI
1) Grip tape is not allowed on the extensions, even in the point where the hands contact the extensions?
Grip tape or rubber is allowed, but only where the hands will be positioned. (Handlebar + extension) (nothing have been updated in the rule regarding this point. Where did you find that?)
2) A rubber grip is not permitted on the extensions, where the hands contact the end of the extensions?
See above
Grip tape is fine. Another great example then of Aussie officials on a power trip. And I wish that were me being overly dramatic but it's regrettably the case.
jorryt
by jorryt
Finished the bike. Focus Izalco chrono milram frameset with 3t Vola bars. 1x10 mechanical gearing. The pedals will be switched to speedplay soon. Image
TimmS
by TimmS
Nice!
What is that chainring?
And can you remove the front derailleur hanger?
jorryt
by jorryt
Thanks!
It is a 56 110bcd chainring of AliExpress. The front derailleur hanger is removable however I do not have the right screwdriver at the moment. But will do.
rainerhq
by rainerhq
It´s not a NW chainring. Do you think it won´t drop the chain?
Domane
Speed Concept
"Nothing compares to the simple pleasure of a bike ride"
jorryt
by jorryt
Not really. The chain is pretty tight and I have already tried it on some bumpy roads.
The roads in Holland are usually smooth.
rainerhq
by rainerhq
Ok.
Its just I have dropped chain on my roadbike while using NW chainring and Shimano non-clutch rear der. Coasting thru bothhole when chain is on the 11 or 12 sprocket.
Chainring was oval though.
Domane
Speed Concept
marcelflash
by marcelflash
This is my Merida Time Warp.
Tririg Alpha X Bar, custom extentions.
tririg Omega X brakes
Dt-Swiss rearwheel old 10 speed with a 11 speed Rotor cassette
Dt-Swiss 80 mm frontwheel
55t front chainring
XTR 12 speed chain and pulleys
Viewspeed QR
TonyM
by TonyM
Why the XTR 12 speed chain on your 11 speed setup?
marcelflash
by marcelflash
I wanted bigger pulleys from Kogel bearings but could not get them here, then I started to think why not XTR pulleys and followed by the chain.
The chain is a lot more silent on the steel rotor Uno cassette, I think because of the longer inner plate witch grips the cassette teeth better.
So far no problem and shifting is really good.
Shimano says that the 12 speed chain can vibrate on some chainrings!
FIJIGabe
by FIJIGabe
Gotta admit, it's a cool looking bike. The downtube is an interesting shape.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Madone 5, Cobia. I own a lot of Treks.
CrankAddictsRich
by CrankAddictsRich
TT season has begun here in NJ...
dropped a chain in the first race and finished 6th, then followed it with two 3rd place finishes.
rainerhq
by rainerhq
Here is my Trek Speed Concept 7.8. Year 2012-13 or something.
Bought second hand and thought I won´t change/upgrade a thing :D but could not resist of course.
Disc wheel is 10sp PRO with 11sp machined cassette. Can´t use the largest cog, because der hits the wheel. So I adjusted the low limit screw and can use 10 cogs.
Domane
Speed Concept
marcelflash
by marcelflash
Have you tried Rotor Uno cassette? It worked for my 10 speed Dt Swiss disk wheel.
rainerhq
by rainerhq
No I haven´t. It doesn´t really bother me. Hope I won´t need this low gear in any race.
Domane
Speed Concept
