The Canyon love thread
Peter_E
by Peter_E
95s10nj wrote:Contemplating purchasing a Canyon Ultimate in size small. 177.5cm tall with an inseam 86.5cm. I ride with my saddle aproximately 77cm. I recently test rode a giant tcr in size medium that felt nice with about 8cm of drop but the giant has a pretty tall spacer stack. Since I'm more leg I think the small is the best fit but what drop would I have with the Canyon with all 27.5mm of spacers? Thanks
I am 1.78 and 75 saddle height and chose the Endurace disc in S which has a bit more stack than the uktimate. Used to have the old ultimate i M and it was fine too but prefer the S.
Skickat från min iPhone med Tapatalk
95s10nj
by 95s10nj
Peter_E wrote:
Tue Feb 12, 2019 4:24 pm
What's your drop with the endurace small with your saddle at 75cm? How many spacers do you have? Thanks
95s10nj
by 95s10nj
crux wrote:
Tue Feb 12, 2019 4:18 pm
95s10nj wrote:
Tue Feb 12, 2019 3:48 pm
I'd suggest a size medium for you. With that you can decrease the spacers and it would still have a nice drop.
The reach on the canyon medium is 391mm compared to the tcr 383mm and I was using the full stack of spacers on the tcr. I wouldn't want to go any longer so I'd probably have to run a 90mm stem min on the medium canyon.
RPMfr
by RPMfr
Hello,
i'm 178 cm with 86 cm inseam (saddle heigth 76 cm). I choose a M. I have approximatly 10 cm saddle bar drop.
Check here : viewtopic.php?f=131&t=83565&start=2310#p1441854
Peter_E
by Peter_E
Hello,
And I have roughly 9 cm drop and 7 mm of spacers on my Endurace S and 75cm saddle height and 1.77 (or1.78) talll.
95s10nj
by 95s10nj
RPMfr wrote:
Fri Feb 15, 2019 11:33 am
Hello,
Thanks. I'm almost positive I'd have to run a 90mm stem on the medium and was worried it may not be the best fit. What's saddle tip to the cl of the bars?
Vermu
by Vermu
Hopefully linked right and works.
Thought about going sub 6. Wasn’t commited enough and now it’s standing at 6,2.
Would be relatively easy to shave off 200g but like the current setup. Oval chainrings are far from lightest.
Peter_E
by Peter_E
Hello,
It is hard to measure the integrated bar/stem. It sweeps back quite a bit. I run hydraulic SRAM so levers are longer fit is good for me even though it is slightly shorter on paper than the old bike (Scott Foil in 54)
95s10nj
by 95s10nj
Peter_E wrote:
Thu Feb 28, 2019 7:07 am
Hello,
Thanks. I ended up ordering the Ultimate in a small and should be here tomorrow so I guess i'll see how it fits. Hopefully the stack ends up being ok. Loved the flash blue on the endurace but I wasn't crazy about the 50/34-11-34 gearing and the flexy seatpost thing. I don't have much elevation here in southern New Jersey so that kind of gearing is uneccessary.
MarekBns
by MarekBns
Hi,
I have H36 on my Aeroad.... How do you guys find this cocpit? I am quite happy with it for riding. But what I do not really like is the Di2 Junction Box placement and handling. I understood Canyon do not sell the CP10 as separate component yet... Anybody changed the H36 for different integrated one or even for stem + handlebar combo? Thanks for your ideas and feedback.
Cheers
d3kalb
by d3kalb
kampiakseli wrote:
Sat Jan 19, 2019 9:05 am
Could you point me to where you got your bottle cages? Thanks!
Henry
by Henry
I have the Ultimate CF SLX 9.0 SL on order and was a bit confused by the new CP10 Aerocockpit. I want a really nice solution for fitting my Wahoo Elemnt Bolt and a light out front (gopro type adapter).
Will this mount fit the CP10 aerocockpit, (screw dimensions as well as hole spacing in the mount? The mount was designed for the H31 aerocockpit.
https://www.ebay.com/p/Lezyne-GPS-Compu ... 3283390926
EDIT: Answering my own question:
This mount seems to work with both the H31 and CP10 so that should work.
https://www.canyon.com/sv-se/accessorie ... 6#id=60442
/EDIT
My idea was to pair it with this adapter:
https://www.trekbikes.com/se/sv_SE/cyke ... Code=black
Have you seen any better/lighter option than the Ebay mount above? My idea is then to put this light underneath:
95s10nj
by 95s10nj
Henry wrote:
Mon Mar 04, 2019 1:37 pm
/EDIT
I just got a new ultimate with the cp10 bar and I purchased the canyon mount from them with the bike then purchased the 15 dollar wahoo garmin adapter to use with my bolt. Wahoo also sells a complete mount that will work with the canyon. Haven't thought about my plans for a light yet.
https://www.wahoofitness.com/devices/ac ... olt-aero-2
https://www.wahoofitness.com/devices/ac ... ter-elemnt
MarekBns wrote:
Fri Mar 01, 2019 8:16 pm
Hi,
Cheers
The new cp10 with the bar end junction box is pretty sweet. It was unexpected since I thought they were still using the bars with the junction box underneath the stem.
Henry
by Henry
Thank you, yes, I ordered that too as a temporary/race day solution but wanted something that also carries the light. Can you please post a few pics of the CP10, specially from underneath would be really interesting to see.
95s10nj wrote:
Mon Mar 04, 2019 4:30 pm
/EDIT
Hi,
Cheers
MarekBns
by MarekBns
Can imagine :-/
Unfortunately Canyon says it is not clear whether and when they will offer CP10 to aftermarket... so I am considering the stem + handlebar (Specialized Aerofly 2) combo....
