The Canyon love thread
ckempy
by ckempy
Hi can anyone confirm the actual weight of the current Aeroad CF SLX 8.0 disc (mechanical)? Advertised as 7.3kg. Thanks.
Snabb
by Snabb
I would really like some new colours. They should do a movistar version of the Ultimate cf slx.
Ride lots!
slake21
by slake21
what the hell is that plastic crap supposed to do? have yet to see one that wasn't cracked
ckempy
by ckempy
ckempy wrote:
Wed Apr 18, 2018 7:15 am
Im trying to compare this with the Scott Foil 20 disc which is qouted as 1kg extra at 8.35kg for similar spec apart from the wheels. My current 2016 Aeroad 8.0 di2 was 300-400g over the qouted weight for size large so im assuming 7.3kg for the Aeroad 8.0 disc might be a bit optimistic.
lwk
by lwk
Long shot, but anyone maybe have an Ultimate cf SLX fork for sale?
Nikisthirdwheel
by Nikisthirdwheel
slake21 wrote:
Mon Apr 30, 2018 8:42 am
I would also love to know this.
Also, has anybody ever swapped batteries on an Aeroad? I have a 2016 8.0 with Ultegra Di2, I want to install the latest shimano battery (BT-DN110) so I can use the e-tube app (Mac user). I have opened up the little bit of plastic on the underneath of the bike near the bottom bracket shell but it looks like the bottom bracket will have to be removed in order to get the existing battery out - somebody please tell me this cannot be true?!
Kesselflicker
by Kesselflicker
Its true :-)
Nikisthirdwheel
by Nikisthirdwheel
Well in that case, all I can say is that is a truly shambolic piece of design for assembly. Infuriating!
Kesselflicker
by Kesselflicker
if you're lucky enough to expand the crank. if the grommet is mounted between the two bearings, the space will not be enough to push the battery out of the bottom bracket opening. Generally, it is easier if a bearing is removed. best to install new bearings right now. have fun :-)
hanakuso1
by hanakuso1
So my Endurace was just delivered and I was installing it. I installed the front wheel and noticed it has way too much space and the fork was flexing. Then I noticed the bearing was exposed.
I looked around and found a piece that looks like it fits. Does anyone know if the photo below is the correct way to install front wheel? Nothing else needed in between it? I'm disappointed there were no instructions in the manual about this.
sfo423
by sfo423
need thru axle cap. looks like you found it.
hanakuso1
by hanakuso1
sfo423 wrote:
Sat May 19, 2018 9:04 pm
Thanks
bjarkisb
by bjarkisb
This is my Canyon Ultimate CF SLX disc mechanical.
I stripped the Ultegra 6800 groupset and sold the mavic wheels and made this weapon.
Specs:
Framesize is small
Sram red etap Hrd with 52/36 and 11-28 with a Quarq Dzero spider.
Enve SES 5.6 Disc wheels with dt240 hubs.
Vittoria Corsa competition 25c
S-Works Power Saddle
Look Keo carbon blade pedals
Supacaz bartape.
FrankG
by FrankG
Had an annoying rattle in the front end of my Aeroad CF SLX which only developed over the last 600km's. It has been baffling me as I tourqued up everthing and couldn't find anything loose!!! Until yesterday, the front shifter for the front derailler and front brake had about 5mm of slack when it was pulled when using the brake. This was ratlling and so was the front direct mount brake as the cable had some slack in it! Don't know how or why but I replaced the inner cable and I'll give it a spin tomorrow night to see if its sorted.
Anyone have a similar experience and if so how did they cure it?
Thanks.
:D 2017 Specialized Tarmac S-Works SL5
:D 2016 CANYON Aeroad CF SLX 9.0 TEAM KAT
Sold
2013 Specialized Venge S-works (1st Gen)
2010 Trek Madone 4.5
2010 Trek 1.2
hanakuso1
by hanakuso1
So I finally installed everything on my new Endurace but I noticed everything seemed to be used. Used but in new condition. Canyon paste residue on the seatpost & steerer, rotors already seen friction from brake pads, anti seize compound on crankarm threads, etc. It's not a big deal but it's kinda disappointing since I have no idea what the previous person did.
