Let's see your Giants
Moderators: maxim809, Moderator Team
mai
by mai
warp wrote:
Fri May 31, 2019 6:43 am
That is indeed the sweetest Defy!
Could you please share details of how did you route the Di2 and brake cables with the Ernova?
I would like to go to a narrower bar on mine but the Di2 routing really makes life difficult as you have to go through the stem.
Thanks for any help!
Thanks for the compliments :)
I had to swap out the original bar as the drops were too short - I reached down when descending, grabbed a handful of nothing, and nearly crashed...! I had Ergonovas on my TCR so something similar (the same?) was a no-brainer.
The bike came from the factory with the Di2 cable routed into the stem through a hole in the stem clamp area and the hydraulic lines enter the plastic stem cover from either side. The Ernova did not have a drilling in the stem clamp area so that was not an option. I looked around, briefly considered getting some Pro bars with routing holes, but I since really liked the Ernova's flare... I decided to improvise a bit.
I ended up routing the Di2 cable together with the left hydraulic line. It was a tight fit entering the stem cover. I tried adding a heat shrink tube, but ended up removing it as it looked worse IMHO. I hope it doesn't look too messy.
warp
by warp
mai wrote:
Sat Jun 01, 2019 8:21 am
Double thank you!
Yeah, after looking at your pictures is sorta obvious you can route the Di2 cable through one of the brake line holes on the stem cover... or if there is not much space, then take a dremel to it and elarge it just a bit.
I was on Deda Superzero on my previous bike and yeah, the Giant bars on the Defy are ... weird, to be polite.
Petterii
by Petterii
mai wrote:
Mon May 27, 2019 5:55 am
Shimano R600 Di2 Climbing Shifters
Shimano R610 Di2 Sprint Shifters
I have one question. How did you connect R610 Sprint Shifters to R9170 levers?
mai
by mai
Petterii wrote:
Wed Jun 05, 2019 11:11 am
Similar to what the OP did here:
viewtopic.php?f=3&t=151321&hilit=r610
But with the R610s instead of generic switches
Petterii
by Petterii
^ Thanks!
Langster
by Langster
2019 Giant Defy Advanced Pro 0
bike ahead composites biturbo road wheelset
Continental GP5000 Tubeless (grrr.....!)
SRAM Red XG1190 11-32 Cassette
Shimano RT900 Rotors
KMC X11DLC Black, Perpetually Dirty Chain
Pioneer SGY-PM910Z/FC-R9100 Power Meter
Tune Speedneedle Sadddle
Arundel Mandibles Bottle Cages
3T Ernova Team 400mm Bars
Shimano PD-R9100 SPD-SL Pedals
7.25 kg :(.......
That's a beautiful Defy! Do you know the weight of the frame?
I've got a Advanced frame at the moment but am thinking of upping it to the Advanced Pro.
squareznboxez
by squareznboxez
Picked up a 2019 TCR pro 1 from my LBM 2 weeks back, being end of the 2019 bikes, they were happy to throw a pair of ultegra pedals in and I bought a set of Specialized Scorch 2 running SPD-SLs. All a bit serious atm, but hoping to push through that stage out and just enjoy this part of my life that allows me to commute by bike daily and have a mate to ride with on the weekends.
Pic shows my XS (i'm a midget 5"5) next to my mates TCR ADV2 in S, noticeably diff between the top tube length.ImageImage
Sent from my SM-G965F using Tapatalk
squareznboxez
by squareznboxez
Double post
sweetmate
by sweetmate
Here is mine need to take some better photos
ddman
by ddman
7.25 kg :(.......
Do you use to bolts for the stem? If so can you share their type and where did you buy them from please? I also have the GPS mount as you. Thanks.
kucyk
by kucyk
Hi all
By any chance does any of you have a pic of giant tcr advanced frame naked i mean without paint?
Wysłane z mojego SM-G970F przy użyciu Tapatalka
jorisee01
by jorisee01
Yes i have. You can look up my thread.
Verstuurd vanaf mijn SM-G960F met Tapatalk
rides4beer
by rides4beer
Picked up the Revolt last summer, it's been fantastic, got the Defy about a week ago, and I'm absolutely in love. Both bikes are great, def loving my Giants!!
bruno2000
by bruno2000
I'm thinking of buying a TCR Advanced SL framekit.
Does anybody know if there is a zero offset stubby?
The stubby with the frameis a 20mm offset.
jlok
by jlok
I think you can flip it 20 or -5mm.
