All Specialized Tarmacs
Moderators: maxim809, Moderator Team
Pukutis
by Pukutis
tbabut wrote:I'm still loving my SL5 :)
Image20210330-L1005829 by Thomas Babut, on Flickr
20210330-L1005844 by Thomas Babut, on Flickr
Which wheels are you using?
tbabut
by tbabut
DT Swiss PR 1400 Oxic with 32mm depth (aluminium clincher)
junchen
by junchen
sychen wrote:
junchen wrote:I have a Tarmac sl6 disc which is rated for max 30mm tire clearance.
For Zipp 303s with int diameter of 25mm, has anyone tried using schwalbe pro one tubeless 28mm? Is there sufficient clearance?
Thanks
Pretty sure that's a yes... Had 28mm tyres measured at 31mm on 21mm internal rims that had heaps of clearance..
Sent from my Pixel 4 XL using Tapatalk
Thanks
Same as this. I use 28mm S-Works Turbos on CL50s come up at 31mm and have no clearance issues
Sent from my Pixel 5 using Tapatalk
Thanks both !
CrankAddictsRich
by CrankAddictsRich
Getting my S-works Tarmac SL5 all ready for the upcoming season.... new chainrings, cassette, chains, cables and brake pads... also have a new set of Corsas to chuck on too.
justRideIt
by justRideIt
Looks awesome. Ages like a fine wine, both the frame as well as Dura Ace 9000.
Which wheelset are you running. What is the current total weight?
2020 S-Works Tarmac SL6 Disc @ 6.35-ish kg: viewtopic.php?f=10&t=159454
2021 Specialized Diverge viewtopic.php?f=10&t=165482
CrankAddictsRich
by CrankAddictsRich
justRideIt wrote:
Wed Apr 07, 2021 1:42 pm
The wheels are Yoeleo SAT60 Superlights. I don't think they sell this exact wheel set anymore.
The total weight is 14.8 pounds or 6.7 kg.
