Pictures of Colnagos
The last photos seem much worse.
No, this is not normal. I guess someone wanted to added some 'gold' paint on the engraved decals so he just got a gold permanent ink and... tried. This is not from factory, that's for sure.
filip00
by filip00
Thanks for the input, guys. I will ask for a replacement.
filip00
by filip00
Edit - I will not ask for a replacement. Weird but....I took a dry rag and polished the lug - and the crappy misplaced paint just went off. What's left is a perfectly decorated lug. I'm baffled.
I have another question though. Is it normal to not have a serial number stamped below the BB? There is just the size stamp.
Mockenrue
by Mockenrue
Isn't it stamped onto the r/h dropout on Masters?
guyc
by guyc
filip00 wrote:
Mon Apr 15, 2019 12:56 pm
It looks like someone just coloured it in with a temporary marker. Odd!
filip00
by filip00
Mockenrue wrote:
Mon Apr 15, 2019 1:14 pm
Hidden in plain sight. It's true, there it is! Thanks, I apologize for colnago-master-newbie questions :oops: will quit the offtopicking here and I'll get back as soon as I build this baby :)
In any case it looks like an original frame and not a copy or something. All the details, lugs etc. are as they should be.
Can you weight it? It should weight less than 1700gr at this size.
filip00
by filip00
One photo from today's ride
maraner161
by maraner161
Looks like it’s going to be nice weather so put some fresh tyres on.
C60 new tyres
C60 new tyres
alistaird
by alistaird
Fist proper shakedown of the resprayed E1... Weird squeak from the BB, guess it's the Overtorque rubber seals...
AImageImage
Sent from my CLT-L09 using Tapatalk
DVR
by DVR
My recently finished build, not light (7.3) but nevertheless I'm happy.
Cannondale SuperSix EVO HM eTap
Cannondale SuperSix EVO HM Disc Ultegra
Cannondale SystemSix eTap AXS
Colnago C60 eTap
Pinarello Dogma F8 eTap
seamaster76
by seamaster76
DVR wrote:My recently finished build, not light (7.3) but nevertheless I'm happy.
Sound strange...7.3 is way too high for this built.
My Colnago Concept (54s) is 7.45 with Sram etap and PM Quarq.
However your bike is stunning!
iheartbianchi
by iheartbianchi
seamaster76 wrote:
Sat May 11, 2019 8:21 pm
However you bike is stunning!
Low 7s is perfectly in line with what I've seen from fairly "stock" C60/64 electronic builds...
Bianchi Oltre XR4
Celeste Matte
Campy SR 11spd mechanical
Bora Ultra 50 tubs
Viseon 5D / stock bits and parts
Bianchi Specialissima Pantani Edition
Campy SR / Chorus 11spd mechanical
Fulcrum Racing Speed 35 tubs
FSA / Deda bits and parts
AJS914
by AJS914
Quick question about tire clearance on newer Colnagos. The V2R and Concept both say they will take 28mm tires. Does that include 28mm tires that stretch out to 30mm?
IvanZg
by IvanZg
V2r, rim brake version in 50s has approximately clearance of 35mm side to side. So you could fit 30mm width tire but in the rear you would probably get a lot of rub between tire and frame while out of the saddle. Also there is not much clearance for rear brake caliper to open so if you'd go with rims wider then 25mm it would be hard to set the rear brake.
