Pictures of Colnagos
RobJ
by RobJ
C64 Disc PKRD (52s) with Campy H11 EPS and Colnago R41 cockpit. Going with the Enve's for now, but considered the Bora 50 DB's to drop some weight and keep the Italian build whole. But it is nice running some wider tires tubeless. If I switch there are some 30mm tubulars out there...
ultimobici
by ultimobici
For the sage of your wrists as well as aesthetics, please sort your lever position out!
https://goo.gl/images/mAoaaS
Calnago
by Calnago
ultimobici wrote:
Mon Sep 10, 2018 6:05 pm
When I first looked at the bike I thought exactly the same thing and was going to say something then just moved on to leave well enough alone thinking if the owner is happy with it why spoil the party, but now that you've commented I'll give my thoughts.
Some bar/lever combinations simply do not work well together. I'm going to say this is one of them. Here's why... Those levers are screaming to be higher on the bars for sure. It's just a very awkard transition from bars to hoods as is. Trouble is, with that very tight radius right at the clamp area, I would bet that moving the levers up even a small amount would have the blades pointing so far forward and further away that reaching them from the drops would be difficult, or very awkward at best. As such, I would not have gone with this combo of bars and levers. These same bars probably work very well with Shimano levers however.
Gary71
by Gary71
it has to be the bars fault! Que Campy / Shimano argument ;)
All jokes aside. That is an impressive rig. i bet it would ride like butter with those Schwalbes.........., there is a lot of wire protruding from the rear derailleur however. Is that normal? It looks like it could get caught something if your not careful
ultimobici
by ultimobici
Gary71 wrote:, there is a lot of wire protruding from the rear derailleur however. Is that normal? It looks like it could get caught something if your not careful
Looks like the Campagnolo supplied rear outer casing has been fitted uncut.
Mockenrue
by Mockenrue
But it's EPS - surely the wire just needs to be inserted a little more into the chainstay?
ultimobici
by ultimobici
Mockenrue wrote:But it's EPS - surely the wire just needs to be inserted a little more into the chainstay?
Doh! Should learn to read!!
RobJ
by RobJ
Mockenrue wrote:
Tue Sep 11, 2018 8:14 am
I agree though the Colnago routing in the rear chainstay is tight. The EPS connector would not fit unmodified. This is my first EPS build so needed to read some more on what else could be done.
gtv18
by gtv18
Nick W.
Veni, Vidi, Velcro
(I came, I saw, I stuck around)
Noctiluxx
by Noctiluxx
Hey guys,
I'm looking to purchase either a rim brake version of Time Alp D Huez or Colnago C64 frameset by the end of this year. I've seen Merlin Cycles having sales on the C64 frameset at prices below $4K. Other dealers that have good pricing are Sigma Sports and Cicli Corsa. Any other legit places I should consider? I'm based in the U.S.
Thanks!
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
Calnago
by Calnago
RobJ wrote:
Tue Sep 11, 2018 3:10 pm
I'm not understanding what needed to be modified in order for the EPS connectors to fit. Looks like the eps connector on your build is not even on the inside of the stay, is that correct?
Here's a couple pics I took when doing my C64 thread and the naked frame....
Just curious what needed to be modified? I haven't actually built one myself yet, but this is the first I've heard of the routing ports not being sufficient to route an eps connector. Are you using the cable magnet routing tools, like the Park cable routing kit or equivalent? Because yes, without these routing kits, some frames can be next to impossible to route the connectors through.
Also, have you got an exact weight, to an accuracy of +/-10grams or so, for the complete build as shown right there in your photos. Not expecting it be a lightweight by any means, again... just curious.
And one final thing, and I realize it's totally an aesthetic choice, but might not the taller top cover for the headset work a bit better here, given the spacers. I just think it might be a bit smoother transition from the top of the headtube to the stem.
Thanks,
Cal
beeatnik
by beeatnik
Cal, Rob's dialing in the fit but also averse to limiting the frameset's resale potential. :P
Calnago
by Calnago
I’m not suggesting modifying the frame in any way, just that I don’t see what needs to be modified as the hole in the end of the chainstay seems plenty large enough to accommodate the EPS connectors. But I haven’t actually built one yet. That’s why I’m asking what modification would be needed.
Martinez
by Martinez
My old friend. Five seasons with me...
Nejmann
by Nejmann
Martinez wrote:
Thu Sep 13, 2018 10:15 pm
Yes! Great build!
