I've had no issues with any of my garbaruk rings. this is my 4th. got 3 direct mount rings. all been very solid. great chain retention on these 1x rings, just as good as wolftooth and absolute black. also have had great experiences with their oversized pulleys cages.
Show us your cervelo?
Moderators: maxim809, Moderator Team
Steve Curtis wrote: ↑Tue Jul 14, 2020 11:38 amNot the best picture but it will do.
Front end is now lower.
Another one of mine
Just set the bike up for the first race of the season (one month away):
I know yellow and tan aren't the greatest match, but I didn't have other Corsas handy.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
What a beast...but but but...you really need to go black on the saddle and bartape or at least on the tyres.FlatlandClimber wrote: ↑Mon Aug 17, 2020 6:43 pmJust set the bike up for the first race of the season (one month away):
Tires is priority one... but all of that is for next season.
she's a beaut! would you mind sharing your wheel and tire specs? i'm looking to see what fits for my 2014 S2Steve Curtis wrote: ↑Mon Jul 27, 2020 8:15 amSteve Curtis wrote: ↑Tue Jul 14, 2020 11:38 amNot the best picture but it will do.
Another one of mine
Both bikes share two wheel sets depending on the wind/ weather.
On the pics they both have Reynolds strike 62mm deep by 25mm wide. With gp5000 23
I now use light bike 56mm deep by 22 internal and 28 external. They are a MUCH better wheelset in every way.
Faster, lighter, stiffer less issues in strong cross winds
With gp5000 25
perfect. that's what i'm leaning towards, a custom light bike wheelset since all modern wheels won't fit my s2. how much room do you have on the chainstay with your current setup? also, is the all blackone an s2?Steve Curtis wrote: ↑Wed Oct 28, 2020 4:28 pmBoth bikes share two wheel sets depending on the wind/ weather.
With gp5000 25
The black bike is a naked s2. S3 and S2 frames are the same but slightly different forks.
In reality it makes no difference.
28mm wide with a gp5000 25 is really about as big as you can go without issues.
I'd say there is 3mm per side at the wides point on the black bike, but that doesn't have any paint so is marginally wider.
The back ends are bonded at the stays just where the brake track is. Depending how much filler they used this can vary from frame to frame.
I still think you'll be ok with the 28mm wide rims
Edit. My rims are RR56C03 which you need to ask for as they aren't on the site.
yeah i'm getting mixed opinions. i was set on getting a pair of hunt 50s (https://us.huntbikewheels.com/collectio ... 8892640301) but the internal width (19mm) and external (27m) might be too wide for my gp 5000s. and i really want to stick with 25c tires for comfort and more control.Steve Curtis wrote: ↑Wed Oct 28, 2020 5:33 pmThe black bike is a naked s2. S3 and S2 frames are the same but slightly different forks.
or i could go with the LB falcon r45 with internal width (17.9mm) and external (25mm) with my 25c gp5000s. thanks again for your replies. any additional feedback is greatly appreciated.
The hunts are pretty crappy in my experience so I'd avoid.
R45s are a wasted opportunity as they're still pretty narrow. Is your frame the same as mine ? If so, I'd go 28mm wide.
Unfortunately this forum is full of people who like to comment on posts without the technical knowledge to back up their facts.
If you check your frame dimensions vs my frames I'll help with whatever you need.
https://weightweenies.starbike.com/for ... 3#p1612203
mines a size 51.Steve Curtis wrote: ↑Wed Oct 28, 2020 8:41 pmThe hunts are pretty crappy in my experience so I'd avoid.
I mean , are the frames identical?
does a picture help?
