Show me your heavy bikes! 10kg+ only!
Moderators: maxim809, Moderator Team
synchronicity
by synchronicity
The first one is ~11kg:
This is my main workhorse bike at the moment (while my road bikes are being built up).
I'm happy with it. It works alright. :|
Note the cassette, 12-21T. :twisted:
I put a new road bike rear derailleur on it, a black 105 unit, but that didn't go so well, the chain got jammed in the cage and it self-destructed on its maiden voyage. :x
Second one, just under <14kg:
The only thing I'm thinking of changing on this bike is downsizing to a 180mm rear rotor as this one is a bit overkill and the rear wheel locks up too easily when descending; hard to find an identical one though. Oh and probably will get a set of offset bushings to lower it a bit. Right now it's too tall, BB too high (fork + shock too long for this particular frame :|). Note the cassette, 13-23T. :twisted:
I have purposely kept these bikes without any super lightweight components.
Because once one light part is on there, I've noticed it's like a disease and everything else on the bike has to follow.
Both 26" wheels still. :oops:
I do have a heavier ~18kg [downhill] bike but that's not ready to show yet, it's getting a few basic upgrades.
Let's see your heavy bikes!
vertebrae | Precision braking and shifting.
vayakora | Eco mouse mats: silk, linen, cotton, ramie, bamboo, etc.
jroy
by jroy
16.5 kg / 36.5 lb
I've gotten a new rear wheel and cassette after grenading the stock one and saved 508g. Still need to replace the front wheel for a few hundred more.
synchronicity
by synchronicity
Yes! I like it I like it!
What calipers are those you've got om there?
I'd like to see more!
jroy
by jroy
The brakes are Sram Guide Ts
The bike is a 2019 Devinci Spartan 29 NX Eagle sie medium
Its an entry level enduro bike; everything is heavy and it could use a lock-out switch for climbing.
Full spec:
Shock RockShox Super Deluxe R DB, 205mm x 65mm shock
Fork RockShox Yari Charger RC Debonair, 15x110mm Boost axle, 51mm offset fork
FSA Orbit 1.5 Zero Stack headset
V2 Pro Riser, 35mm clamp, 780mm width bar
V2 Pro, 35mm clamp, 50mm length stem
Devinci Performance, lock-on grips
SRAM Guide T, Centerline rotors, 200mm front brake
SRAM Guide T, Centerline rotors, 200mm front, 180mm rear brake
SRAM NX Eagle, 12-speed derailleur and shifter
SRAM GX Eagle, Super Boost crankset
SRAM DUB 73mm threaded bottom bracket
E.13 TRS+ 9-50t cassettee (upgrade)
Front wheel
V2 Comp Wide DB, 36mm inner width
Front: Novatec D791SB-B15, 6-bolt rotor, 32 hole, 15x110mm Boost
Maxxis Assegai DC/EXO TR 29" X 2.5" Tire (upgrade)
CushCore insert (upgrade)
Rear wheel (upgrade)
Stans Flow MK3
Maxxis Minion DHR II DC/EXO TR 29" X 2.4" Tire
Cushcore insert
SDG Fly Mtn
TranzX dropper, 1x remote
