Let's see your Swiss Machines // BMC
addictR1
by addictR1
JHeiro wrote:Image
Oh wow those are some neat looking wheels. What are those?
CLEAR
by CLEAR
Bikeahead Biturbo road
addictR1
by addictR1
CLEAR wrote:Bikeahead Biturbo road
Never have to true them?
addictR1
by addictR1
bilwit wrote:Image
Trying a new look, covered the red/blue highlights with black vinyl, handcut the logo with white as best I could. Didn't come out perfect but I figured no one will really notice when I'm moving anyway. Down to 8.155kg as pictured.
What degree stem is that?
Klaster_1
by Klaster_1
addictR1 wrote:
Mon May 27, 2019 7:22 am
Extralite makes Hyperstem in 6 and 12 degrees only, so that's a 12.
latsride
by latsride
Replaced my older 2012 SLR01 with this RM01! (Will update with a nicer side image in a bit)
First impressions: it’s so much heavier but it ‘feels’ faster, smoother, much more controlled and it can stop. Cannot emphasize how nice it is to stop when I tell it to.. My old Zipps were not up to the task, especially in the rain. I wasn’t sure about disc brakes at first but glad I got them.
Changed the saddle and bars but it sits at 7.64kg. A bit of work to do on this one. If I can justify it and find myself climbing more again, I’ll replace the frame with the SLR01 next season, but this is plenty fun for now. (Although from what I’ve found, the frameset weight difference is only about 100g)
addictR1
by addictR1
Did extralite end up fixing the biting issue that the stem would bit into the fork steerer issue?
addictR1
by addictR1
A shot from last evening before sun goes down.
15.4lbs (after removing the water bottle, Fly6 and lezyne hand pump with mount.
bilwit
by bilwit
addictR1 wrote:
Wed May 29, 2019 7:28 pm
They addressed it by rounding off the edges of where it clamps, but supposedly some people on here have still had issues with it. I've used it across three bikes and haven't had it happen to me though. I'm comfortable in using it so long as it's torqued to spec.
addictR1
by addictR1
thanks for the update. i think i'll stick with my kalloy uno. i had the extralite before and it left a mark on my addict steerer... :(
Canch
by Canch
My BMC:
2019 BMC TM02 Frameset
Campagnolo Chorus 11sp Groupset
Tririg Omega X brakes
Vision Metron TFA handlebar
VENN VAR77 with DT240s Wheelset
Corsa Speed tubeless tires
Prologo seatpost
Ceramicspeed OSPW and chain
MC356
by MC356
Here is my custom TMR01
Sitting pretty at 7.2kg
Could go lighter but shes already more bike than I will ever need :P
BMC TMR01
Niner Air 9 RDO
addictR1
by addictR1
MC356 wrote:Here is my custom TMR01
How do you like the shift qty on the carbon QRing?
MC356
by MC356
addictR1 wrote:
Sun Jun 02, 2019 5:58 am
Not too bad. I have to change gears when the Q is at its largest part, if I change gears when is not at that point the chian falls off sometimes...
This was the same when I had mechanical gearing too.
BMC TMR01
Niner Air 9 RDO
rainerhq
by rainerhq
"not too bad" :D
I think its very bad, if chain falls off.
Domane
Speed Concept
"Nothing compares to the simple pleasure of a bike ride"
