Le club Time
Calnago it's not a stiff wheel that can cause a problem but less stiff hubs and spokes:
http://www.slowtwitch.com/Tech/Debunkin ... _3449.html.
Here is a wheel stiffness comparative test (older but still indicative). See lateral stiffness numbers (related to brake rub). LW is way better:
https://www.roadbike.de/laufraeder/test ... 8464.9.htm
Calnago
by Calnago
Ok... I'll accept that. And yes, those links are the theoretical discussions I was referring to. So the Boras need the brake pads open a bit more than the Lightweights due to the fact that they are more "lightly" spoked so to speak, not necessarily because there's a difference in stiffness in the rim itself. I did go back and have a look at that reviewers video once again and he does call out "rim" stiffness as opposed to "wheel" stiffness, so that makes more sense now. My bad.
I wonder if the reviewer ever stopped to give his brakes a turn or two to try to eliminate the brake rub he was experiencing. That would have been the first thing I would have done, before going on a video saying there was brake rub. I would only call that out on a video if I couldn't actually eliminate the brake rub. I don't think it's fair to call that stuff out, if the only reason it's happening is because it's not set up properly. He's basically implying that it's the wheels fault, when in fact maybe the brakes just needed to be let out a bit more for those particular wheels, in exactly the same way I have to let out the brakes for the Boras vs a set of Lightweights.
I will get a chance to test out the AKTIV fork on a Skylon very soon. I don't think it's the same fork as on the Alpe d'Huez bike due to it's weight, but it incorporates the same basic technology. Looking forward to it. It's the heaviest road fork I've ever come across by a large margin, so I would expect it to have quite a damping effect for that reason alone. And that's not necessarily a bad thing.
AJS914
by AJS914
Bikeradar did a test. Too bad they didn't include an aluminum rim to compare to:
https://www.bikeradar.com/us/road/gear/ ... ame-49344/
AJS914
by AJS914
I think it's dumb when reviewers point out things like the gears not working correctly or a rim rubbing. So, the mechanic didn't get it spot on, so what, that doesn't have much to do with a frame review.
Calnago wrote:
Sun Feb 11, 2018 6:31 pm
Yes, it is the same fork. It is a heavy one but it works. It does not work like a suspension fork but it eliminates vibrations at certain frequencies. Its capabilities are shown when going downhill at high speeds and the tarmac is not perfect It provides confidence and helps the rider move faster. Other than that it is not easy to discern it from a normal fork.
miltmaster3
by miltmaster3
Let’s start ..........
πατα τραβα ρε
:thumbup:
miltmaster3
by miltmaster3
πατα τραβα ρε
miltmaster3
by miltmaster3
7600gr Image
πατα τραβα ρε
Looks great. :thumbup: More and better photos please.
havana
by havana
Lugs are stil 3K carbon, so it the head tube. The rest is shiny black.
Build list
Frame/fork: Time VXR frameset size L
Shifters, derailleurs, brakes: Campagnolo Potenza
Brake pads: Reynolds blue
Wheels: 38mm FCC (18 mm internal), Bitex hubs 20/24 CX-ray spokes
Tires: Vredestein Senso Superiore 25 mm
Cables: Campagnolo
Crank/PM: Quarq DZero 5x110 NHB
Chainrings: 50/34 SRAM Red 10sp
Cassette: 12-25 Shimano 105 11sp
Chain: Campagnolo Potenza w/ KMC missing link
Bottle cages: Aliexpress Time bottle cages
Headset: Time Quickset
Bars: PRO Vibe Round (repainted, w/o logo's)
Stem: FSA (repainted, w/o logo's)
Seat: Specialized Phenom 130 mm
Tape: Fizik Microtex
Chain catcher: K-Edge
Most "innovations" in cycling are solutions for non-existing problems.
:thumbup:
Time Alpe d'Huez, creating the prototype model:
https://www.youtube.com/watch?v=jkiUwzKW8Uc
nemomaya
by nemomaya
havana wrote:
Tue Apr 03, 2018 10:15 am
Build list
Cables: Campagnolo
Hello, I am currently riding a Vittoria corsa g + of 700x23 in my colnago, I would like to change to the Vredestein Senso superior, I see that you have them mounted, how do they work? I can not find information thank you very much
miltmaster3
by miltmaster3
Just a reserve e mail from time
They will send me a new pair Of saddle cup to fix my issue!
They are very fast and very effective
Any of you that you have any problem just mail them
πατα τραβα ρε
