Moderators: maxim809, Moderator Team
Kumppa
by Kumppa on Sun Mar 28, 2021 11:29 pm
Have you ever considered to switch back to non-aktiv or do you totally prefer aktiv?
Almost a half year winter break from road cycling so I don't remember exactly how much heavier aktiv fork felt on corners vs my other bike with 300 g fork but need to do some heavy cornering test rides with same wheels. However, good points.
Jrtyoung wrote: ↑Sun Mar 28, 2021 10:32 pm
The question could be - can you live with your bike knowing you might be missing out on the “full Time ownership experience”
This is the hardest part, can't get everything I would like to.
Jrtyoung
by Jrtyoung on Mon Mar 29, 2021 3:22 am
Kumppa wrote:Have you ever considered to switch back to non-aktiv or do you totally prefer aktiv?
True - I do have a brand new Activ fork, never been cut, which came off a frame I donated to be cut up by Leucher Teknic (frame had a factory defect) If your interested DM me
Guardian
by Guardian on Tue Apr 06, 2021 1:24 am
Thanks, really enjoying it. I had it away for 3+ months during the winter. I really wanted to ride it, but too much road salt out there. Winter and gravel bikes got all the workout.
openwheelracing
by openwheelracing on Thu Apr 08, 2021 6:43 am
Alpe Dhuez owners, how do you let water drain after a wash? There is a cap with short screw.below.bottom bracket. It holds inner plate that routes shifting cables. The cap is tightened at all times to keep cable tension and there is no drain hole.
Has anyone drilled a hole on the cap for drainage?
Do you grease or anti seize the screw to prevent problems in future?
openwheelracing
by openwheelracing on Sun Apr 11, 2021 11:26 pm
So I got tired of loosening cap under BB to drain water. I drilled a small hole on the cap itself. Hopefully that works. I definitely don't like the design.
Also, I hope someone can help me determine if the correct ferrules are used in my build.
openwheelracing on Mon Apr 12, 2021 9:19 pm, edited 1 time in total.
Samboraman
by Samboraman on Mon Apr 12, 2021 5:27 am
Hello Le Club Time members,
Long time Time owner - VXS, RXR Ulteam and now about to be the proud owner of a Scylon Edition Française. Have very much enjoyed reading all 60 pages of posts and learning a great deal in the process. I shall post some pictures of my bikes in their different guises (wheelsets etc.) and also of the new build Scylon.
VXS in its final iteration with 105 and Fosmics (Novatech 65mm tubs). Pictured with Edco Albis wheelset and Vottoria Corsa tires. Started life with Dura Ace and Fulcrum wheels and original seat post back in 2006 when I bought the moduel new.
Llanberis
by Llanberis on Tue Apr 13, 2021 10:40 am
openwheelracing wrote: ↑Sun Apr 11, 2021 11:26 pm
I think for cable entry at downtube / chainstay, it is recommneded to use the cap with long tongue like this (as outlined in SHIMANO delaer's manual), which would help reduce the bend:
nafaiutb
by nafaiutb on Wed Apr 14, 2021 5:25 am
Samboraman wrote: ↑Tue Apr 13, 2021 7:18 am
Pictures of the RXR Ulteam:
UlTegra 8000
Different wheelsets:
DT Swiss 1400 Dicut
Mavic Cosmics 40mm
Fosmics (Novatech)
Lightweights (current wheelset)
His and hers matching RXRs (different stem on the 54cm as the bike was not sold with it)
Easton EX70 areobars finish off the cockpit nicely
Frame came with the drilled seatpost bolt... but being the other side of 100kgs I opted to buy the newer style cap (from Australia as the only place I could get one) as I had read abotu the seat tube cracking in some cases.
Pictures of the new Scylon to follow
What's the red band at the top of the seat post in pic 2?
Samboraman
by Samboraman on Wed Apr 14, 2021 6:32 pm
The red band was, I think, a marker for where the seatpost should be inserted up to before being tightened. It was a very think sort of tape and didn't come from time. The bike was shod with Campy Bora Ultra (red and whie decals) so I think there was a bit of matching going on wherever possible.
