Show us your sub-6kg builds
Fluoro7
by Fluoro7
That blue Berk is un_real.
@AUOC10C6 What, 4.5kg without cutting the steerer tube? Show off... :wink:
AUOC1OC6 wrote:Here's my recent build: AX Vial Evo D in Size 54 @ 4.585 kg
Wilier Zero7 (1st gen) Fluoro
RIP Cervelo R3 2012 White on Black
jooo
by jooo
poynt wrote:Can we post MTBs in here, or is this for roadies only? Nearly finished my HT Scale that hopefully should be around 5.6kg
Of course :thumbup:
deltree
by deltree
Djohns wrote:My 2015 Cannondale SuperSix Evo Himod @ 5.90kg
Nice build. Is the front wheel (or tyre) mounted on backwards? Pretty sure Conti tyres say "Handmade in Germany" on one side and "Continental" on the other.
rideintospace
by rideintospace
I don't think there is a direction for the gatorskin tubulars. The tread pattern is identical whether you mount it one way or the other. It also says "Gatorskin" on one side and "Sprinter" on the other.
Reason: removed the quote.
Djohns
by Djohns
Didnt know that. Thanks for the the added info.
I did check it too at first bec i had it installed in an lbs, but then the pattern is identical whether you have it on the other side it's still the same so i didnt bother anymore.
Thanks. For the build it's still not final going to get a wheelset to shed som more weight target would be atleast 5.5kg
Reason: removed the quoted quote. guys, you are replying to each other. In a normal conversation, do you also repeat what the other person has said before you answer it?it?
ardi69gain
by ardi69gain
Update my VB-R-077 now sub 5kg
Sent from my SM-A710F using Tapatalk
Wookski
by Wookski
NeilPryde Bura SL- 5.8kg with Bora/ Veloflex Arenberg & 5.36kg with LW Obermeyer/ Veloflex Carbon
Delorre
by Delorre
Just perfect Wookski! :thumbup:
cerro
by cerro
Wookski: Awesome, that's a bike in my taste :)
/jonas l
RyanH
by RyanH
The Crumpton at 5.7kg
DeiviX
by DeiviX
Arfer01 wrote:Image
5.7kg
http://youtu.be/v1PBptSDIh8
by Nefarious86
RyanH wrote:The Crumpton at 5.7kg
Bike porn :D
Using Tapatalk
Peeza21
by Peeza21
5.975kgs, could easily loose some weight with different tyres, but otherwise very happy with this bike.
Cannondale Supersix Evo HiMod 2012 viewtopic.php?f=10&t=148290
Cannondale Caad12 2017 viewtopic.php?f=10&t=143217&p=1389852#p1389852
Imaking20
by Imaking20
Current:
Wilier Wonka | The Dentist | The Bucket List
Retired:
Specialissima | Evo | T2 | Blue | Project C6.0 | Felt AR FRD | Colnago C59 NERO | 2014 S-Works Tarmac | S-Works Venge | Wilier Cento Uno SL | Tarmac SL2
maverick_1
by maverick_1
TIME VXRS 2006 @ 5.41kg
