the Cipollini club
Moderators: maxim809, Moderator Team
Trainingofoz
by Trainingofoz
Hello to all fellow Cipollini owners.
Can someone help me with a Bond headset bearings? Mine need replacing but all the markings are gone. What are the correct diameters and angles? Thank you in advance.
GS100
by GS100
Hi all.
I thought I'd post in here directly after slightly derailing another thread on 'Cipollini bikes UK' with my saga.
Anyway here is my NK1K, I originally bought the frameset in August which had a defective seat tube - sorted out with a replacement frame no quibbles thanks to Paligap the UK distributor who were great to deal with.
First ride out today and much relieved that it was not a let down- stiff, fast on the flats and zero flex uphill. The front end is incredibly direct and rigid and will take a little getting used to. My TCR doesn't lack in that regard but it's not a patch on this.
Bit of a porker at 7.67 kg but electronic Chorus 11s does weigh a bit vs record 10s mech on my TCR.. you honestly can't feel the extra 900g when you stomp on the pedals since it's so rigid.
Build was reasonably straightforward, especially bb386 and wide tubing meaning insertion of battery etc up the BB was ok (wouldn't go in the aero seattube.. Charge cable (EPSv2) can be accessed by removing the under BB blanking plate..
Only just moved to 11s and the ratios are great, 12-27 and low position I think suits my 'diesel ' engine. EPS is a revelation.
The frame itself is immaculately finished in shiny black white with carbon 'exposed'.
Cheers.
GS100
by GS100
Just realised l none of those pics was didn't a drive side shot whoops
Bobbyc123
by Bobbyc123
Hi all,
I know there was some chat about it on the other thread but there didn't seem to be any resolution.
Does anyone why some frames are being sold without the electronic hole in the top tube undrilled and some with the hole drilled?
Looking at the nk1k manual online now. You can see the spot where they leave a dent in the frame where the electronic access port is. You can actually see the two spots in the finish where both cable access ports are supposed to be but remain unopened. You can also make out a square shape behind the holes in the layup, reinforcing perhaps?
Does anyone have any experience drilling this hole?
I still don't quite understand why they would be selling some frames drilled and some not, while leaving the dent where the hole is supposed to be.
Thanks!
nestornnk
by nestornnk
Bobbyc123 wrote:
Sun Dec 06, 2020 11:25 pm
Hi all,
Thanks!
Hi
Early frames were drilled at the factory.
Now Cipollini stopped this and advises each owner to do it by him self saying it will not void the warranty.
We never do that and it is much better to use a down tube port.Not ideal regarding looks but much safer solution...
one60
by one60
NK1K owners....is the stock seatpost cradle/clamp suitable for oval (carbon) rails? If not, is there a part # for the correct cradle?
GS100
by GS100
one60 wrote:
Thu Jan 21, 2021 4:09 pm
Yes. Just put in an sworks power saddle on mine, which is ovalised 7 x 9 I think
MrMojo
by MrMojo
I've got a Fizik Arione 00 saddle on mine. That has oval carbon rails.
2021 Colnago Master
2020 Colnago C64
2017 Colnago C60
2017 Colnago V1-R
2014 Cipollini RB1K
2008 Colnago Extreme C
2005 Colnago C50
2001 Colnago C40
1996 Colnago Tecnos
tomgru
by tomgru
finally, a fresh DOLOMIA arrived:
nonamed
by nonamed
tomgru wrote:
Sat Feb 06, 2021 5:06 pm
Lubię to :) Custom painting? What size and real weight of the frame and fork?
GS100
by GS100
Lovely. But shame about the disc brakes. There was a promise of a 5.5kg rim brake version. This might be my dream bike. Anyone seen any updates?
cveks
by cveks
Great looking bike this Dolomia but I dont like disc brakes either. What is point having climbing bike with disc brakes and make it 550 grams heavier.
Oms
by Oms
Who's got experience with running a Shimano chainset with the Shimano 41mm pressfit BB, combined with the Cipollini provided adaptor cups? I'd prefer not to have any creaking (which itself could mean rubbing!).
So far, other options I'm looking at are the Hambini and Token Ninja BB386 to 24mm BBs.
tomgru
by tomgru
nonamed wrote:
Sat Mar 20, 2021 4:43 pm
Now I don't remember the weight of the frame itself. It's L size in custom painting.
New wheels are coming tomorrow, so I will add new photos in a few days.
By the way, I will also weigh.
tomgru
by tomgru
Unfortunately, I am not an outstanding photographer.
Weight 6.85 kg with pedals, bottle cages and Garmin holder.
