The wheelbuilding thread
Marin
by Marin
Stiffness and tensile strength are 2 very different parameters.
alcatraz
by alcatraz
Have you noticed spoke elongation at a given tension is very high in the smaller spokes. That must really play with the limits of the manufacturing processes.
Seems that elongation and elasticity is less of a problem than tensile strength if the spoke companies continue to offer and introduce spokes that elongate several millimeters at normal tension.
I wonder what they do under riding. That must be something else completely.
bm0p700f
by bm0p700f
Spokes don't elongate by several mm under tension. A CX ray does not even stretch by 1mn at 1300n and after serious stressing.
FilmAt11
by FilmAt11
Before I glue the tubulars, any comments on this build? Is heads-in NDS OK? Thanks!
Rider: 72kg
Hubs: BHS Superlight
Spokes: Sapim Race
Front wheel (20h): 469g
Rear wheel (24h 16:8): 626g
bm0p700f
by bm0p700f
Heads in stresses the flange more and there is an increased risk of fatigue failure of the flange.
If that's the bhs triplet hub you would have had a stiffer rear wheel with the conventional hub.
You have built it now though.
FilmAt11
by FilmAt11
Thanks. Which lacing pattern would you recommend with a conventional hub?
alcatraz
by alcatraz
Shouldn't he do 2x NDS if he's got 3x DS? The spoke tension difference must be extreme with 3x/radial.
If some spokes are as low as 30-40kgf then they might break or loosen by themselves, no?
/a
Marin
by Marin
The tension difference between 2x and radial is very small, so the relative difference to the DS will be almost the same.
bm0p700f
by bm0p700f
16:8 is triplet it has to be radial NDS but is should be radial heads out.
With a conventional 24H hub then its 2x both sides. This will be a latterially stiffere wheel. I could work out by how much.
alcatraz spoke loosen off of the wheel is not stiff enough to stop spoke unloading. if the wheel is stiff enough to stop spokes unloading with low tension then there is no problem. look at a wheel in the round rather than at individual characterisitic in isolation.
An example my own set of BORG50C clinchers have miche swr hubs with 49/16mm flange to centre spacing rear. There is not much tension nds even with the ds done up to 1300N. Then there are tubeless tyres fitted to take more tension away. The wheels do not go out of true.
Tension balance is red herring, I don't even consider it. Doing everything to increase it at the expense of other characteristics is not good wheel building in my view. Making the wheels stiff enough to stop spoke unloading is.
Triplet does have some advantages but it really needs hubs made specifically for it and rims drilled for the extreme non drive side bracing angle.
FilmAt11
by FilmAt11
Thanks for the recommendation - 2x both sides. Noted for the future. I had a Williams System 19 from several years back laced 2x/2x that was really solid.
shimmeD
by shimmeD
I've laced mine heads-in NDS (better bracing angle being my reason) and am going to ride it (Veloflex 23mm already glued on) against bm0's advice. I'll have to check the tensions, the NDS side were a little less but I didn't note down.
Film, what rims are those? Mine weigh 1044g differences to yours being Pillar 1420 spokes and the 210g 2:1 bhs hub (don't know which model), with Farsport 23x25mm tub rims.
Less is more.
bm0p700f
by bm0p700f
it will probably be fine I did say there is an increased risk of flange failure not there will be flange failure.
shimmeD
by shimmeD
:beerchug: Thanks Malc, I appreciate your posts and value your opinions.
Less is more.
FilmAt11
by FilmAt11
Those are Loltra 20x20.5mm rims (239g, 240g).
shimmeD
by shimmeD
Jolly good looking wheels, congratulations :thumbup:
I did think of going heavier gauge on the NDS like CX-Sprint but decided against it having already decided to go 23mm wide rims rather than 20. Should be sweet for a low-powered light-weight in any case.
Less is more.
