The wheelbuilding thread
bm0p700f
by bm0p700f
For a 290mm sapim race and brass nipple weight is 7.25g for reference.
Nixster
by Nixster
Hi All,
I've read the thread, OCD clearly but I found it interesting! Mostly :D .
So a question:
I have a Farsports 50x25mm tubular rear wheel, 24 spokes laced 2x DS, radial heads out NDS on a 2:1 Bitex ED hub. Had it 2 seasons and it's been well behaved and checking it with my newly acquired Park TM1 it is evenly tensioned and appears well built.
But.
It's not that stiff, or having read Roger Musson's book, it may be that the rim is very stiff but anyway I get movement at the brakes, enough to rub when climbing out of the saddle.
I'm light (60kg) but I had a thought that I could improve the NDS bracing angle slightly by re-lacing it heads in, sacrificing a little tension in the cause of lateral stiffness. With only 8 spokes on the NDS it's hard to see them ripping the flange apart?
So, given the risks of re-building it and me making a Horlicks of a currently pretty good wheel:
1 - is it worth it?
2 - could/should I re-use the spokes? (I'm guessing change in length will be trivial but thinking about fatigue in the elbows)
Nipples are SILS in a fetching red colour if that makes a difference.
Thanks!
Nixster
Marin
by Marin
No, yes.
It won't be perceptibly stiffer, but you might break the flange.
bm0p700f
by bm0p700f
the main problem is the hub. the bitex 2:1 is not a proper 2:1 hub in book as the flange spacing are not optimises for 2:! lacing. you will get a stiffer wheel with a std bitex hub. for the wheel to be stiffer with 2:1 lacing you need a NDS flange at least 45mm from centre.
So if you want a stiffer wheel dont mess about replace the hub.
Lightweenie
by Lightweenie
So a small update on my rear-wheel Mavic Open Pro UST build. It took quite long to finish because it was really hard sourcing the rim.
I decided to build a slightly better wheel than initially planned. So I went for a DT 350 rear hub DT revolution 2.0/1.5/2.0 spokes aluminum nipples on the NDS and brass on the DS. The wheel has 28 spokes, and is laced 2-cross. I also decided to use it for trying out tubeless.
The build went quite well, took me only about 6 hours compared to 12 for my first rear-wheel build - and this was mostly because I forgot to lube the rim-nipple interface and had a lot of DS-nipples round off, so I replaced all DS nipples which took some time. One thing that slightly worries me is that I have 109kgf on the DS but only 52kgf on the NDS, but lets see how it holds up with time.
Thanks a lot for all the comments/suggestions!
bm0p700f
by bm0p700f
dont worry about that tension balance. I have personal wheels with under 400N NDS and they are quite stable.
by Nefarious86
Chasing a wide alloy rim for an everyday road disc wheelset. What's the current hotness to build 28/28, more than likely onto hope hubs in 12x100/142
Sent from my SM-N950F using Tapatalk
Using Tapatalk
Lightweenie
by Lightweenie
@Nefarious: I have not yet tried out my Mavic Open Pro UST build yet, but it sounds to me that the disc version of the rim fits all your criteria.
by Nefarious86
They do look good, my only concern with them was how tight some people find them when installing tyres.
Using Tapatalk
whosatthewheel
by whosatthewheel
Nefarious86 wrote:They do look good, my only concern with them was how tight some people find them when installing tyres.
... which ultimately limits your choice of tyres significantly... seems an unnecessary hassle
by Nefarious86
Yes, especially considering they will be used with regular tubes/tyres.
Using Tapatalk
whosatthewheel
by whosatthewheel
Nefarious86 wrote:Yes, especially considering they will be used with regular tubes/tyres.
No go area then. Beside the tightness, my understanding is that Open PRO UST have a pressure limit of ca. 87 PSI, which in essence means tubeless only... unless you use 28 mm tubed tyres.
The moral is pointless to spend extra for UST tubeless rims and then use them with inner tubes
by Nefarious86
They will probably be wrapped in Speshi 25/28 Roubaix tyres at about 80/85psi :)
Using Tapatalk
crbeardy
by crbeardy
Hi WW community. Building my first set of wheels courtesy of BDOP and having some trouble with the rear 2x lacing. Ive followed the Musson book to the letter after reading it a few times. The front radial wheel was a piece of cake but i'm having trouble with the 2x spokes on the NDS. The 2x spokes seem to get caught on the hub flange and come out of the hub with a large bow/bending. It all looks pretty wrong compared to the DS.
Anyway, any help would be appreciated. Rim is assymetric and its 24H 2x
thanks in advance
Lightweenie
by Lightweenie
Just increase the tension slowly and they will settle. It always starts like this from my (admittedly limited) experience
