Tubular Repair
Forum rules
bcmf
by bcmf
Geoff wrote:
Sat Feb 23, 2019 5:13 pm
Don't bin it, just store it until you have enough tires to bother shipping them off to get fixed.
Last time I did that , and it wasnt Rons fault, I got hit with customs duty when they arrived back in Ireland. Customs werent even interested in the fact I sent them out in the first place.
Effectivley negated the cost of getting them repaired.
Rossin67
by Rossin67
For what it's worth, I was in a pinch and glued the basetape on with some Loctite flexable adhesive that I had. I will never use anything else again, it's perfect. Dries fast and no issues when riding. Rode it about 600 miles or so before the tire finally wore out. When I peeled the tire back off the rim the tape held.
audioblazer
by audioblazer
Hi need some info . Is Continental GP4K S2 Tubular punctured repairable ?
1415chris
by 1415chris
It's seamless construction, so if you mean whether it can be open for repair, answer is nope.
Smaller punctures can be fixed as any other tub using sealant.
audioblazer
by audioblazer
Yup open up for repair. Thanks
addictR1
by addictR1
What and how would you guys recommend in fixing a cut like this? I put about 200 miles tops on these veloflex carbon.Image
joeyb1000
by joeyb1000
addictR1 wrote:
Tue Jun 25, 2019 3:51 pm
I've used crazy glue (I'm assuming it's just a cut in the tread)
Calnago
In Memoriam
by Calnago
I’ve been trying this neoprene cement that I picked up at a Dive Shop for cuts exactly like that. Even if they don’t spread, without filling then crud etc will embed itself in there and eventually flat your tube. This stuff is black, flexible, and seems to be ok. Quite a few various products you could try I suppose...
1415chris
by 1415chris
I use Super Glue. At one point I tried Super Glue Flex, as the name suggests for gluing flexible materials, but I couldn't see the difference.
addictR1
by addictR1
Calnago wrote:I’ve been trying this neoprene cement that I picked up at a Dive Shop for cuts exactly like that. Even if they don’t spread, without filling then crud etc will embed itself in there and eventually flat your tube. This stuff is black, flexible, and seems to be ok. Quite a few various products you could try I suppose...
Sweet! I’ll give that a try. Would come in handy to use on my ROKA shorts when the time comes too.
KCookie
by KCookie
I'm glad I saw this post as now I have just ordered a tube to hopefully fix a side wall split. Nearly new tyre so worth a try.
Also some advice please.
My rear tyre kept going flat over night so I used a little orange seal and was fine the next day. Went for a ride Friday and I heard that horrible noise when you get a puncture, i could see a small hole as the orange seal was trying to escape. Held my finger over the hole for a few minutes and all was good to get myself home but i also noticed the other damage to. Pic attached. Should I ride with this tyre with that damage or to far gone or could I use some of the neoprene cement I've got coming.
Cheers Image
Sent from my SM-G960F using Tapatalk
jekyll man
by jekyll man
KCookie wrote:
Sun Jun 30, 2019 12:31 pm
Cheers Image
Thats shagged mate...
Official cafe stop tester
KCookie
by KCookie
Thought as much, will bin it. Thanks for the reply.
KCookie
by KCookie
Calnago wrote:
Tue Jun 25, 2019 4:54 pm
Hi Calnago,
My tube arrived today so over the weekend I will attempt to fix my sidewall puncture. My question is, after you use the cement would you still add a little orange seal or is that not necessary.
Cheers
Calnago
In Memoriam
by Calnago
@Kcookie: To be clear, I only use that neoprene cement to fill cuts in the tread etc. that might otherwise just become cavities for crud to get embedded in and ultimately cause a puncture. I don’t use it to actually fix a puncture. For example, the last time I used it was due to a piece of embedded glass which created a cut in the tread, then eventually a small puncture in the latex tube (Arrenberg). I used a little sealant which sealed the puncture. But since the cut in the tire still left a gap I just used the neoprene cement to try and fill that gap so as to prevent any road crud from embedding in the gap and causing another puncture. If I get another flat on this tire then, since I added some sealant to fix the first puncture, there may be enough sealant left to fix the second puncture. If not, I just add a bit more at time of puncture. I try to only use about 10-15ml, and I don’t use it as a preventative measure. I found too much sealant in a high pressure road tubular ends up clogging the valve, especially with the every ride inflation ritual that needs be done with latex tubes.
