Tubular Repair
LeDuke
by LeDuke
I have a pair of once-used Challenge CX tubs. Like, warmed up on road tires, did a couple of laps, raced for 45min. The tread is coming off in a couple of places.
Anyone have a good recommendation for what I can use to re-glue the tread? As it's a CX tub, I'd like it to be soft and supple still.
sungod
by sungod
there's an article about fixing tread here...
https://www.bikeman.com/bicycle-repair- ... ead-repair
bcmf
by bcmf
Got a quick question for you.
I dug out a flat tub , Vittoria Pave 25c, to have a look at either sending it to tire alert - not an option as postage is too expensive- or fixing.
I pumped it up a little and found where the air was coming out.
When I looked closer it turns out the tyre casing is torn just outside the basetape and I can see the tube.
There was less then 200 km on the tub.
Where the outer casing is torn would be still on the glue on the rim.
Is this for the bin? Or is it worth trying to fix?
TIA
sungod
by sungod
depends how big the cut/tear is
with veloflex i patch it with a piece of carcass from an old tyre, about 15-20mm (cut it oval shape)
glue it to the inside with barge cement (or another durable contact adhesive), finish the rest of the repair and sew up, before gluing the basetape, put tyre on a rim and inflate to max pressure, if there's no sign of a bulge it's fine
i've done this for cuts c. 5mm with no problem
bcmf
by bcmf
Thanks.
Ah it wouldnt be bigger then 5mm.
Better gets some waxed dental floss etc.
Have a few old tyres that can be sacrifriced for a patch.
sungod
by sungod
fwiw i use dacron line for sewing them, 20lb - 30lb rated, you can get a reel for a few quid/dollars/euros
it's sold as 'backing line' by angling equipment suppliers, available in bright colours, which helps old eyes see where the stitches are!
dntong
by dntong
Does anybody have a link to youtube vid showing how to repair a tubular tire? About to transition for the first time, and wanted to be prepared when a flat does happen.
fdegrove
Tubbie Guru
by fdegrove
Hi,
No idea about youtube other than a lot of non sense but basically you want to use a X type of sewing.
All of which is explained already in this thread.
Cheers, ;)
bm0p700f
by bm0p700f
What do you guys use to fill ghe cut in the carcass. Would wet suit repair glue work well or is there better.
fdegrove
Tubbie Guru
by fdegrove
Hi,
[quote][/Would wet suit repair glue work well or is there better.quote]
Should work as it contains polyurethane. In general I can't be bothered with these small cuts though.
The ones on the sides of the envelope are the ones I worry about but there's much you can do about those anyhow short of coating them with liquid latex on a regular basis.
Cheers, ;)
fabriciom
by fabriciom
Tried my fist tube repair on a continental sprinter and this morning at 7 am the tyre blew up and it woke me up.
It seemed like a simple job but I guess I made a mistake some where.
Next time I won't glue until I live it out with air for at least 1 day on the tyre stretching.
jekyll man
by jekyll man
fabriciom wrote:Tried my fist tube repair on a continental sprinter and this morning at 7 am the tyre blew up and it woke me up.
The good thing about conti tubs is, they're strong enough, and easy enough to repair.
Pull it to bits and have another go. Either you didn't repair the puncture itself well enough, or sounds more likely that your sewing wasn't tight enough, and allowed the inner tube to poke through like a hernia.
Official cafe stop tester
fabriciom
by fabriciom
I think it was the string I used wasn't strong enough.
The inner tube is destroyed not way to repair.
sungod
by sungod
you can replace the inner tube with a new (latex) one, there's some info in this thread, also outside ww...
http://www.sheldonbrown.com/brandt/tubular-repair.html
http://www.bikeforums.net/classic-vinta ... ement.html
fdegrove
Tubbie Guru
by fdegrove
Hi,
fabriciom wrote:I think it was the string I used wasn't strong enough.
I suggest using high quality dental floss a la Johnson & Johnson which can be found at the local pharmacy in most European and American countries.
Bottom line, strong, silk, waxed and no stretching.
Anything else is mostly down to sewing practice.
Cheers, ;)
