The tubular sealant thread.
Calnago
by Calnago
nemeseri wrote:Very useful, thanks for sharing. I'm sure that's only me, but how do you use the hose with the sealant bottle? I detached the orange thingy and attached the hose, but when I squeezed the bottle, nothing went into the hose.
Not sure what you mean, the little orange cap twists off and you twist on the hose (it attaches to the cap exactly the way as the cap you just took off). Then you just push the open end of the hose onto the valve stem (after the core has been removed), and squeeze some sealant in there. Have the valve about between 4 and 5 o'clock when you do this so the sealant that you squeeze in runs down into the tube rather then gets sucked back up as soon as you release the squeeze if that makes sense. It will when you try it. Then put the valve core back in, rotate the puncture spot to the bottom to let the sealant get at it for a bit then pump it up. I use a hand pump and not C02. Sometimes it can take a little while for it to seal but it usually does. I rarely have to resort to putting on my spare tube, but I do carry one with me.
savechief
by savechief
Here is the Slowtwitch test that was referenced earlier in which Orange Seal and Bontrager performed the best.
http://www.slowtwitch.com/Products/Thin ... j4155.html
Sent from my SM-G930V using Tapatalk
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
Lafolie
by Lafolie
great stuff...cheers guys
by Nefarious86
That looks like a decent pocket solution
Using Tapatalk
amey
by amey
I use this in my tubulars, never had a p***ct*r* though so cant comment on its effective.
MikeyBE
by MikeyBE
So far so good with Caffèlatex fixing a 2mm glass cut on a pave 25mm tub!
Sent from my 6039Y using Tapatalk
davidw
by davidw
I carry a small bottle of the standard formula Orange Seal. Got a glass cut on a conti comp and it has sealed it up no problem. Only issue is they only sell it in massive bottles that may be inconvenient for carrying on the bike. Luckily I have plenty of 1 and 2 oz bottles from work.
Sent from my SAMSUNG-SM-G930A using Tapatalk
istigatrice
by istigatrice
what type of bottles are people using to carry their sealant? I've got a stans 2oz/60ml bottle but that doesn't seal very well... Ideas?
I write the weightweenies blog, hope you like it :)
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
russianbear
by russianbear
I've had the best luck with Orange seal in my tubs.
sungod
by sungod
after a few years of using tufo extreme (very successfully) i thought i'd try orange seal, the downside with tufo being the limited shelf life
it seemed pretty thin vs. the tufo, but maybe that wouldn't matter
tried it for the first time yesterday on discovering i had a slow leak, squirted in about 20cc, inflated a bit, spun the wheel to spread it, then positioned with the puncture at the bottom, inflated fully, waited, seemed ok, then after a couple of minutes...
the result was quite spectacular, i'm torn between orange haze and orange rain, overall i think hendrix won
at least i was at home at the time and could grab a cloth to catch the spray before it coated everything in the vicinity
i ordered some more tufo extreme!
markyboy
by markyboy
I use tufo great stuff,whats the shelf life of tufo?
COLNAGO C60 SUPER RECORD EPS
Pinarello f8 sram etap
Eddy merckx 69 ultegra disc winter bike
commfire
by commfire
I picked up some Bontrager TLR
I will add this in the event of a flat. Does anyone have any insight how it will react with a Co2 cartridge versus a pump?
Fixie82
by Fixie82
I used some Bontrager TLR in a recent tubeless set up. Seated the tyres using Co2, no issues. Just inflate with the valve at 12pm after letting the sealant pool at the bottom. Can still hear the sealant sloshing around after a couple of months.
sungod
by sungod
markyboy wrote:I use tufo great stuff,whats the shelf life of tufo?
hard to be certain as there's no production date, i bought four in mid-2015 (it worked out cheaper at the time)
used two ok, but when i got to the third and fourth, they were already starting to set in the bottle (unopened)
once opened, the older bottles set fast, i'd normally expect to get 3 uses out of a bottle, the last bottle would only give two and one shots respectively
they were stored somrewhere cool/dark but presumably something volatile is seeping out over time
perhaps storing in the fridge would help extend life, but it seems best to plan on 12 months
